What polk speakers are these (pics included)?
c_corie
c_corie Posts: 138
edited September 2008 in Speakers
Bought these for cheap, have no idea what series/year they are, also what's all the junk near/on the tweeter assembly, its almost yellow/white stuff?
Post edited by c_corie on
  • Face
    Face Posts: 14,340
    Monitor 11's with the Peerless tweeter.
  • c_corie
    c_corie Posts: 138
    any idea what the crap is on them, and what they're worth? thanks for the info.
  • Face
    Face Posts: 14,340
    Lasareath wrote: »
    face, the 10's don't have a base like that
    Since when did SDA's come with Peerless tweets? ;)
    Plus, they're about a 1' too short to be 2A's or 2B's. I edited my post, they're Monitor 11's, just with a funky base.
    c_corie, look at the back of the speaker. One the binding post cup(speaker terminals) there be a tag with some numbers on it. What are the first three numbers/letters?
  • c_corie
    c_corie Posts: 138
    I have work soon, so i'll checkt tomorrow, (the speakers are out in the garage) but if that is oxidation or whatever it is, can i get it off or at least try without harming the speaker/tweeter?
  • candyliquor35m
    candyliquor35m Posts: 2,267
    hook em up and enjoy. nice find and they look to be in good condition.
  • c_corie
    c_corie Posts: 138
    I forgot to tell you guys i got them for...............
    $19 at the goodwill store! Amazing right. They're a little gross not just on the tweeters so maybe a damp cloth would work, and some windex type stuff on the cabinets.
    mhardy6647 Posts: 34,019
    They look to be Monitor 11s to me.
  • c_corie
    c_corie Posts: 138
    So I'm going to hook them up tomorrow, and can't wait to hear them. Any idea what i should clean them with though as they are a little scummy?
    Also any tips on placement or anything, and also i read stuff about the 8 or 10 inch speaker being a passive radiator? So only the 6 1/2s are doing the work?
  • schwarcw
    schwarcw Posts: 7,341
    You can clean the cloth with plain water and a soft scrub brush. The drivers look fine. Use a little Windex on the metal part of the tweeter. Do NOT touch the tweeter dome with anything.
    The Polk speaker is a sealed cabinet. The moving drivers creat the air motion that "radiates" the big passive radiator. Toe them in a little to image them properly. Tell us how they sound. Good luck and welcome to Club Polk!
    Carl
  • Face
    Face Posts: 14,340
    If they sound boomy, throw them on some short stands.
  • wizzy
    wizzy Posts: 867
    These are worth nothing.
    Pack them up and send them to me, I will dispose of them properly.
  • c_corie
    c_corie Posts: 138
    both tweeters do not work BUT both fuses are also shot. is that the problem? haha.
  • Joe08867
    Joe08867 Posts: 3,919
    I think they are Monitor 11's. Tens are a bit shorter aren't they?
  • c_corie
    c_corie Posts: 138
    also the fuses say 312 3/4a 250v, will any 3/4a 250v correct size fuze work? what does the 312 mean?
    heiney9 Posts: 25,217
    My memory is foggy but I though the original 10's had a base like that at one time.
    They aren't SDA's of any generation and I though Monitor 11's came a bit later. Hard to tell with the goofy angles the pics were taken with. Is there a label of any kind on the back of either speaker?
  • danger boy
    danger boy Posts: 15,722
    you should be able to find some fuses for your new speakers.. more than likely your tweeters will work again once you get the fuses replaced.
    I too think they are Monitor 11's. somewhat rare. Value? is anybody's guess.. they are worth more then $19 I can tell you that. I would place their value in the neighborhood of $150 to $225.
    I'd keep em though if I were you. :D
    PolkFest 2012, who's going>?
  • danger boy
    c_corie wrote: »
    it appears to be some kind of oxidation.. try some soap and water on the metal part of the tweeter.. but really in all honesty.. it's not that bad. they appear to be pretty dang clean to me. no rust on the tweeter or tweeter screws, that's very common. I would say try some mild soap and water if that doesn't work.. I wouldn't try anything to harsh on them.. i'd just leave it alone. keep the grills on and no one will ever see it. ;)
  • candyliquor35m
    if they sound good, I don't usually worry too much about cosmetics. they are old and are supposed to have some wear and tear on them. just like on antiques road show. something that has been refinished can be worth half as much as something original and untouched.
  • Joe08867
    I would just clean the speakers themselves. But these look pretty clean over all. And they have Peerless tweeters.
    The oxidation would come off easy if you use a little WD40 on a rag and wipe carefully. Don't touch the dome of the tweeter or the surrounds on the mids or PR.
    Nice set of speakers.
  • c_corie
    c_corie Posts: 138
    So they sound good but I have anothe question. They are marked right and left channel on the back, any idea why? Did some one do this or are they L/R specific? Also one seems slightly louder then the other, but my room is not set up that great, and you can not really sit in the "true" middle of the speakersm, any thoughts?
  • danger boy
    if they are monitors.. which those are..... then don't worry about it being marked left or right.. show us a picture of the entire speaker terminals on the back of one of the speakers.. I am just curious to see it.. as mentioned, we don't see monitor 11's very often in here.
    if one of your speakers is lower volume than the other.. chances are that one of your mid bass drivers isn't working. since there are two.. it may be difficult to tell some times while listening to music.
    without playing any music.. gently push on the driver, but not the cone part of it.. see if there is any scratchyness to it.. do this for all four drivers. other than that.. I would try one speaker at a time. and unplug one of the wires on the driver and see if the other one is working.. then reverse it.. and try it again.
  • c_corie
    c_corie Posts: 138
    There is some scratchyness on all 4 drives, also do each of the 2 drivers (per speaker) cover the same range, or is one set to do lower bass? It almost seems like 1 tweeters is quieter/slightly more muffeled sp? then the other.
  • c_corie
    c_corie Posts: 138
    ALSO- i just moved the right speaker to the left and left to right, and one is def a little louder then the other.
    I can hear slightly better in my left ear, so im putting the louder speaker on the right to even that out (i played guitar through loud amps, with the right ear facing them since i was 10, im 23 now:o( ) ANYWAY is there truly no "left or right" speaker for the monitor 11s? Also i looked on the back, serial number starts with 11 then a space, so i'm thinking they really are 11s
    EDIT: I think they sound different now that they are switched in position, am i nuts? Or is one midbass crossed over higher, hence when switched the speakers seem slightly smaller soundin, cause the higher midbass is closer to the listener?
