sub needed with lsi25?
StevenFo2
StevenFo2 Posts: 11
Hello
Is a sub needed when using lsi25? If a sub is needed which is better a psw1000 or dsw600?
Post edited by StevenFo2 on
  • curved
    curved Posts: 664
    edited September 2008
    It depends how big your room is, music taste, etc. Listen to them...if you like the way they sound, get them. Break them in slowly, and if you're still not happy with the bass response, etc, you can always add a sub or two.
    Room dynamics have a big play in a speaker like this.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • Sami
    Sami Posts: 4,634
    Music, HT or both? For HT, I would add a sub, mainly music I don't think I would. Don't care much for the Polk subs myself, I would shop around.
  • hockeyboy
    hockeyboy Posts: 1,428
    I agree with both of these guys. You can always add a sub later, because the 25's give a nice base response. When I was buying, I personally went with the LSi15's because I planned to run dual subs from day one. That being said, the 25's are great and a PSW1000 would be the preferred IF you were going with a Polk sub.
    If you are planning on HT most then consider SVS. Otherwise a Velodyne would be great.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
