Sticky Speakers
Lawrence Grand
Lawrence Grand Posts: 21
edited September 2008 in Speakers
Anyone know how to remove the stickiness from the speakers? I guess after many years, the adhesive that bonds the veneer to the cabinet works it's way through to the surface. I tried alcohol, only with marginal success.
Post edited by Lawrence Grand on
  • Lowell_M
    Lowell_M Posts: 1,660
    No idea what you are talking about... but, are you related to George?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • madmax
    madmax Posts: 12,434
    Many speakers are sticky from the factory. If that is the case you should leave them alone. They are dust collectors for sure...
    madmax
    Vinyl, the final frontier...
  • Shannon W.
    Shannon W. Posts: 568
    Goo off would work. Or any non abrasive citrus sticker removers. Good Luck.
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
  • George Grand
    George Grand Posts: 12,258
    None of that stuff works, and if it does, the next day the stick is back. EPI 100's I believe were sticky when they left the factory. Great little speakers but I've yet to find a pair that doesn't have that **** all over the cabs.
    No he's not.
    F1nut Posts: 51,780
    Since you say veneer, I'll assume you are talking about real wood veneer and not a vinyl covering. It's not the glue coming to the surface, it's the finish applied to the veneer that has become sticky. This can happen for a number of reasons, old wax and/or polish being but one. If it is just a build up of gunk, wipe them down with paint thinner. If that doesn't work, then the finish is past it's lifespan and the cabinets will need refinishing.
  • Lawrence Grand
    Actually, F1nut, I misspoke. It is a vinyl covering and not a wood veneer. Any thoughts on eliminating the stickiness? Thanks.
    LG
    treitz3 Posts: 19,992
    Orange oil.
    F1nut Posts: 51,780
    I'm much less familiar with the properties of vinyl coverings, but Fantastic cleaner is pretty good at removing grime and junk from a host of plastic based products, so I'd try that. I seriously doubt that the adhesive has bled thru.
