wine bar/lounge speakers suggestion
edited September 2008 in Speakers
looking into buying speakers for my wine bar lounge, which is about 1100 sq f. thinking about installing 6 speakers.
need help on deciding which polk speakers.
prefer not to have subwoofer on the side somewhere.
prefer each speaker to have its own woofer.
same goes for an amplifier. which amplifier would be a good choice?
Post edited by ninomakota on
    I went with B&W 685's in my bar/lounge.
    http://www.bowers-wilkins.com/display.aspx?infid=2301&terid=2447
    I have Polk everywhere else in the house, but also wanted a good low end without a sub. Amp will depend on power needs. If you get 8 Ohm speakers they will be easier (and less expensive) to drive. IMO if you are going Polk go with LSi9's which have a terrific low end. That being said, you will need a lot more clean power to make these sound great because they are 4 ohm speakers. Are you planning on using a Receiver and an Amplifier, or just a receiver?
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
    Need more info- you looking for in-ceiling or in-wall? Bookshelf or on-wall? Floorstanding? Also- how loud?
    -Eric
    -Polk Audio
Welcome!
Welcome!
