Need recommendation on receiver choice for Lsi setup
Greg Sattler
I will be running the following 5.1 setup:
Lsi25's - fronts
Lsi7's - surrounds
LsiC - center
PSW1000 subwoofer
I know the Lsi series is power hungry and I would like to hear what you guys think an appropriate receiver choice would be to drive this particular setup.
Thanks.
Lsi25's - fronts
Lsi7's - surrounds
LsiC - center
PSW1000 subwoofer
Thanks.
Post edited by Greg Sattler on
Sunfire Ultimate II. (Look on eBay or Audiogon for one used) don't try to run them off some everyday run of the mill receiver like I did, you will only be disappointed. I would even try to go separates, your LSi's will thank you later.
Shannon50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
Here is a starting point, guaranteed to make your LSi's sing.
http://www.polkaudio.com/forums/showthread.php?t=71784
Receiver that would drive LSis good are from the following manufacturers: Rotel, SunFire, B&K, Outlaw, and of course the big boys: Krell, McIntosh, etc.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
I have an Arcam Preamp/Processor AVP700 and Rotel 1075 amplifier. If you are interested in both of them, please let me know.
Thats a would be a great place to start and a heck of a price..
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
first wlcome to Club Polk.
Amp, and a Pre. Why spend a huge amount on an AVR when that is the main piece of gear that gets out dated the fastest?
Ben -
Shannon W. wrote: »Thats a would be a great place to start and a heck of a price..
Shannon
Thanks guys. I should have given more detail before but I was pressed for time. Anyway, what I originally had in mind was an Onkyo 706/806/876/906 for the pre-processor along with an Emotiva XPA-5 amp.
Thoughts? -
That would be fine.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Hmmm, I beg to differ. The Onkyo of days gone used to be good to great sound. I tried the $1400.00 model and it was in the loop for about 15 minutes and then back to the store.
Don't mean to be blunt but you wanted my thoughts. Well, there they are.
Greg Sattler wrote: »Thanks guys. I should have given more detail before but I was pressed for time. Anyway, what I originally had in mind was an Onkyo 706/806/876/906 for the pre-processor along with an Emotiva XPA-5 amp.
Thoughts?
As a side note to this discussion, would there be a problem with running an amplifier, like the one mentioned above, on the same circuit (wall outlet) as the LSi25's since they have a powerd sub, or do I need to have a dedicated circuit put in for either the amp or the 25's? I don't want to trip the breaker all the time. -
What size circuit are you running on? I'm having my electrician (good buddy
) run me a seperate 20 amp circuit for my amp and avr. My TV, DVD, etc will be on the same on as it's on now. Also upgrading wall outlets in both. Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
I'm using the HK AVR 247 as a pre/pro until the UMC-1 comes out (hopefully by the end of the year) with XPA-5. If you can save, I'd highly recommend getting the MPS-2 instead. You wouldn't believe the level of sound you'll get with LSi + MPS-2 combo
Well, I am actually in the process of acquiring all my gear at once.....I like it quick and painful all at one time:D so I am not actually running anthing at the moment.
What I have currently is just a standard 15 amp circuit. I too would be running everything (TV, DVD, amp, pre-pro/avr, etc) off of this circuit as well which is why I am wondering if one circuit can handle all of the equipment
Do you think everything could all be run on a single 15 amp or do I need one or more dedicated 15/20 amp circuits? -
I read that the UMC-1 and XMC-1 are due out by year end. I have not done a whole lot of reading about them though. Does anyone have any thoughts about how these may compare to a mid range reciever (~$1500) as a pre-pro.
I also was mainly considering the XPA-5 as I only have a 5.1 setup. I don't forsee a 7.1 or anything else in the future, at least in my current house. Unfortunately I don't really have a spot for the other two speakers. At any rate you think the MPS-2 would sound better than the XPA-5? How come? Thanks. -
Welcome to Club Polk Greg.
Just get the XPA-5 and be done with it!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
The Emotiva is discontinued:( the replacement should be in later this year.
Ben -
For my HT, I'm using the Onkyo 805 as pre-pro, and the Emotiva XPA-5 for the amp, and I think it sounds awesome--Now I'm not running my LSi-9s on that rig, but I have had them on there running with no problems.
If you go the 5 channel amp route, you can use the two rear amp channels in the Onkyo if you decide to go 7.1.
As far as Circuit size-I have my entire HT rig on one 15 amp outlet right now (that apparently also has a light and ceiling fan on it), and it's running fine. Of course I am going to be running a separate circuit very soon, if for nothing else to help eliminate any possible power quality/noise issues. I've measured the setup to pull about 11 amps max when watching a DVD, very loud.____________________
Pool: Atrium 60's/45's -
Ben
According to the website they are available. -
Ben are you thinking about the MPS-1 vs MPS-2?____________________
I would personally put in another 20amp circuit (especially if you're already spending the kind of money that you are) and upgrade the outlet. I also agree with iskandam. The MPS-2 is a beast!!! It's quite a bit more powerful than the XPA-5. Granted you said you're not going with a 7-channel, but I would use 4 channels for the front 2 channels. Then you're left with center and two rears.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Greg Sattler wrote: »I read that the UMC-1 and XMC-1 are due out by year end. I have not done a whole lot of reading about them though. Does anyone have any thoughts about how these may compare to a mid range reciever (~$1500) as a pre-pro.
The UMC-1/MPS-2 combo should smoke any flagship receiver out there. I only had a 5.1 LSi set up too when I had the MPS-1 so I used the remaining 2 channels to bi-amp my LSi15s. Doing that really opened them up to levels I never thought possible with that set up. In my experience, having owned both the MPS-1 and XPA-5, the MPS-2 is the best match with LSi in every area - imaging, soundstaging, clarity, detail, and bass extension. There is a reason why it cost twice as much and imo it's worth every penny. Just make sure you have a dolly or something, I almost broke my back carrying that beast into my rack :eek:
If I had to do it all over again I wouldn't have replaced the MPS-1 with XPA-5. It wasn't until I brought Ben's silver ICs and cables into my rig that I felt the sound approached some of the greatness of the MPS-1.
I ran everything on a 15 Amp circuit with no problems at all, but after reading DarqueKnight's detailed analysis of the benefits of going with multiple 20A circuits I will be heading in that direction after my wallet recovers from the upcoming UMC-1 purchase
