Setting LSi 9's & LSi C to large in HT setup.
Shannon W.
Guy is this a bad idea? I set the x-over points on the low end @ 250hz. and left the others where the receiver had them at factory.
so far they sound better but I'm worried to run them at my normal listening levels. I know the specs for the 9's say Overall Frequency Response 38Hz - 27kHz, Lower -3dB Limit 50Hz, Upper -3dB Limit 26kHz and the LSi C says Overall Frequency Response 40Hz - 27kHz, Lower -3dB Limit 52Hz, Upper -3dB Limit 26kHz.
So where should I set the x-over point at on the receiver with the front sound stage set to large?
Shannon
Shannon
50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Post edited by Shannon W. on
Try setting your crossover at 80Hz & set all speakers to "small". Chances are that you'll really like the way it sounds."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
250hz on the sub? That is awful high. With those speakers the sub/fronts should both be at 80hz. For music you may want to go with 40,or 60hz. 250hz is for crappy little cubes.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Can the SVS even play that high?
I agree with the others, definitely stay around 80 Hz."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
xover to the lcr @80z - any higher you will start cutting off in the human voice frequency range
http://en.wikipedia.org/wiki/Vocal_rangemy 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
The crossover on your sub should be set as high as possible (250hz should be fine). The crossover in your AVR should be set at 80hz with all speakers set to small. (experiment with crossovers above and below that setting as well.)
This recommendation is based on a normal setup of sub hooked to LFE out on your AVR and speakers hooked to the speaker outputs.
Now for your setup , 80 hz is just perfect cause the bass-reflex, frequency response 50-26,000 Hz, Ring Radiator tweeter, dual Dynamic Balance drivers, ARC and Power Ports, real wood veneer
Michael
Setting all speakers to small would most likely set them at an XO point of 150+. You need to manually set the XO point to match the subs XO point.
Ben -
while I agree 80hz is a good place to start, I am curious out of the specs you mentioned, what (other than maybe frequency response) brought you to that conclusion?
Michael
I am thinking it is either the ring radiator tweeter, or the real wood veneer that drove him to the 80hz XO point:D
Sorry I could not resist:p
Ben -
I have mine set to large, but mostly because I'm using Y cables to send signal to 2 mid woofer/subs, essentially running them and the LSi's as a large full-range set.
I did this because, a.) I had the subs laying around, and b.) there is some mid-bass that gets lost when pairing the 9's with only a sub. It sounds fantastic. -
My processor will only allow my woofer X-over go to 99hz and i set the tweeter at 10khz. I left the mid at 1.0 khz. is this right or should I set the tweeter back down to around 2.7khz? but now these things are set back to small and they are flat out a different speaker.
Shannon50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
I don't know your processor, but unless you are bi-amping the speakers, messing with tweeter/mid crossover points without bypassing the factory crossovers is a futile effort.
I agree with the 80 hz sub setting and small setting for your speakers. They simply can't handle the huge rush of effects sounds like crashes and blasts.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Ok. Thanks Guys.50" Samsung Plasma
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
I have the sub set at 80htz, but i was talking about the eq setting in my receiver that I'm using for a pre amp. I have settings for the L/R mains, center, L/R surrounds and rear L/R surrounds. I can set each speaker separately. that is what I was asking help on guys. sorry if I didn't speak clearly. on the Bass,Mid and tweeter frequency settings along with gains.
So now with that said, where should I baseline my settings? I don't have a RTA so I just need a rule of thumb.
Polk LSiC Center
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Ben
Great problem sort out in my absense though !
it is like these are what i own now where i started fixing with teh 80 hz , i thought of liek would help the guy too !
