B&W DM6 for SDA-1A swap
altecman
altecman Posts: 52
edited August 2008 in Vintage Speakers
Someone has offered to swap his pristine B&W DM6's for those modified SDA-1A of mine. This model B&W is one of the few I haven't yet heard, as this person lives on the other side of town I want to get a quick heads up on what these speakers are like from the options of others.
The Polk SDA range of speakers is pretty thin this side of the planet and am a little cautious about releasing them as I have really taken to the way they project music. Would the B&W's be in the same league as the 1A's? Any advise would be appreciated!!
Post edited by altecman on
  • gdb
    gdb Posts: 6,012
    edited August 2008
    Hi, I would think that to get a clear idea of how the new speakers will suit you, you really need to audition them in YOUR listening room, connected to YOUR components. Hearing them under those conditions will give you your answer. Maybe you could agree to a long term "Honeymoon" period with an out clause if either of you decide you'd rather have your old speakers back.
    Good luck!:)gdb
  • altecman
    altecman Posts: 52
    edited August 2008
    Went and had a listen to the B&W DM6's, all I can say is that the modified 1A's are a lot better in many ways, the B&W's are just so flat and uninspiring. I suppose it just proved to myself finally that the Polks are good and that they are keepers.
    F1nut Posts: 51,923
    edited August 2008
    I've never heard a B&W that didn't sound flat and uninspiring.
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    altecman wrote: »
    Every time I go out to hear new gear I come home and listen to my SDA's and I am happy. A few mods, and SDA's can really put out some nice sound:)
    Ben
