TARA LABS HELIX 8 BIWIRE or something else?
TouchOfEvil
TouchOfEvil Posts: 967
dmc-electronics has the tera labs helix 8 biwire for $5.00 a foot unterminated right now.
I'd like to run my fronts with it to see how it sounds vs the stranded stuff i have right now.
Is this a good price for the wire?
Should i look into a differant wire that would be better/just as good for same or less price?
Thanks for the help guys.
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
Post edited by TouchOfEvil on
  • TouchOfEvil
    edited August 2008
    Anybody used this wire before? Just looking for some guidence on this wire vs others...i searched but found very little on this wire on the board.
    I found some audioquest type4 for $4.00 a foot
    also found some type 8 for $10.00 a foot....
    any ideas?
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    links please.
    The AQ is really a good cheap cable. I have not used the terra labs.
    Ben
    Ben
  • TouchOfEvil
    edited August 2008
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • ben62670
    edited August 2008
    I would realy like to hear from someone who has tried the TARA LABS HELIX 8 BIWIRE SPEAKER CABLES, and the AQ type 4's. I have the AQ type 4's, and the CV4's. They are both great wires, but the Tara helix 8's look very tempting. The price at $5 a foot in bulk is plenty cheap enough.
    Ben
    Ben
  • TouchOfEvil
    edited August 2008
    I think i'm gonna order some of the tara labs helix 8. I need about 15foot of it to wire up my fronts then based off how it sounds i can go from there.
    I seen some type 4 on audiogon and ebay so might try to get some of it as well to compare the two.
    I was mainly wanting to try the Tara Labs because it's a solid core and i have not heard any solid core wire yet.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • ben62670
    edited August 2008
    I love solid core wires in the mid grades. I have found the detail to be spot on. The bass to be hard hitting, and the mids to be very pleasent. I would love to hear your thoughts on both wires if you get to try both. I know used AQ's you could most likely recover your purchase if you like the Tara's more.
    Ben
    Ben
  • TouchOfEvil
    edited August 2008
    well i just placed a couple bids here and there on some type4 wire and i'll order some of the tara labs tomorrow after i measure out how much i will need for sure.
    Might do the center as well and try out the front three.
    Ethier way if i like ethier/both the surrounds won't get it for a while lol. Bedroom would need a total of 47 feet and the living room would need right at 70 feet.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • ben62670
    edited August 2008
    Front stage is the most important. Seeing cash flow has never been excessive here I felt money spent on rears was a waste for me YMMV.
    Ben
    Ben
