old RT-7
Josephlogston
i have a pair of RT-7 that are well used the 8" wolfers are ready to crack on the rubber surrounds what kind of speaker that are good enough to relpace them with, i love these speakers, any one that have these know what i mean
thanks,
joe logston
thanks,
joe logston
Post edited by Josephlogston on
If you really like the way they sound, I would call Polk direct and purchase through them. Plus, it's a 7 1/2 inch woofer. If they don't have the exact replacement, I'm sure they will have plenty of good recommendations. Otherwise, you can always order some from partsexpress. They will have some NICE 8 inch woofers - this is what I would be replacing them with:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=297-310Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
