Lsi9 and Lsic on a HK AVR-435
Does anyone have any experience using these 4-ohm speakers with Harman's high current AVR models? Does the protection circuit trip? I would use 8-ohm speakers for the rears.
Post edited by neurot on
I'm sure you will be fine with the HK,you shouldn't trip at all unless you are going to try and make your ears bleed. That said, you'll need an amp and use the HK as a pre to get the most out of those Lsi's.
They're some good amps for sale right now on the forum that will do your lsi's proud>
Welcome to Club Polk
HK makes one of the better receivers for hard to drive speakers. Like said though you will probably want to add an amp later.
Ben -
Here is a link to an HK amp that is for sale on this forum. You could probably pair it with your 435. I'm not an HK guy by any means, but it's nice to have branded components.
http://www.polkaudio.com/forums/showthread.php?t=45137My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
