Looking to upgrade speakers
bilbeau
bilbeau Posts: 34
edited August 2008 in Speakers
Hi All,
You can see from my signature what I am working with. I am looking at upgrading my speakers from these Infinity Qe's to something about the same size but a bit more sensitive. I really have to pump up the watts to get these to work properly.
I'm looking for a damn good 2 way. Say 90 - 95db/w/m and can handle 100 watts plus
Any suggestions?
http://www.billbeau.net
Carver
Twin M400 Power Amps
Pioneer
SA-9500II RT-909
TX-8500II CT-F1000
SG-9800 PL-518
RG-1 PL-540
PDR-609
SAE
5000
5000A
DBX
224
228
400X
400XG
Infinity
Qe 2-way Speaker
Post edited by bilbeau on
  • BjornB17
    BjornB17 Posts: 752
    edited August 2008
    Do you have a specific budget?
    I the Monoitor or TSi series are the easiest current-model polks to drive (Maybe R series as well). Apparantly the RTi4 and RTi6 speakers are pretty easy to drive as well but i think all of them are around 89 or 90 db sensitive. Any higher level polks (RTi towers or LSI) will be harder to drive.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
    treitz3 Posts: 19,243
    edited August 2008
    Welcome to the forum. Yes, a budget will help us to help you..
  • zingo
    zingo Posts: 11,258
    edited August 2008
  • bilbeau
    bilbeau Posts: 34
    edited August 2008
    Guess I should have added a budget. Thanks for telling me :)
    Im looking at anything from 300.00 to 500.00 a pair.
    I am also thinking of using my SA-9500II that is rated at 80w/ch at 8ohm and 100w in 4 ohms as a preamp and adding a power amp. Im thinking something in the 175 to 250 watt at 8 ohms area. I know the Pioneer Spec 4 and Spec 2 would fit the bill but damn they want some big dollars for those as they are highly collected.
    These old Infinity Qe's dont wake up till around half volume there efficiency is 89db@1W/m
    Carver
    Pioneer
    SA-9500II RT-909
    TX-8500II CT-F1000
    SG-9800 PL-518
    RG-1 PL-540
    PDR-609
    SAE
    5000
    5000A
    DBX
    224
    228
    400X
    400XG
    Infinity
    Qe 2-way Speaker
  • NotaSuv
    NotaSuv Posts: 3,864
    edited August 2008
    Spec 4 here locally for $425 in great shape..same guy also has a mint M 25 for $500
  • bilbeau
    bilbeau Posts: 34
    edited August 2008
    I like the Polks but those Klipsch are damn nice. I need to audition some. Gots find some local.
    The Spec 4 for 425 is a bit on the high side then adding shipping is just a bit out of range for a 150 watt power amp. The M25 is a nice amp also but once again a bit pricey and with shipping its just too much. I'll wait for something to come up local. They come up on Craigs List now and then.
    Carver
    Pioneer
    SA-9500II RT-909
    TX-8500II CT-F1000
    SG-9800 PL-518
    RG-1 PL-540
    PDR-609
    SAE
    5000
    5000A
    DBX
    224
    228
    400X
    400XG
    Infinity
    Qe 2-way Speaker
