why not the pci over the pc plus SVS subs
faster100
faster100 Posts: 6,124
edited January 2003 in Speakers
Let me know why or why not to get the pci series SVS sub over the more exspensive pc plus series... Just wondering
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited January 2003
    You get:
    1) A more capable driver - the dB-12 by TC Sounds with about 3-4 dB more max output above 30 Hz, and about 5-6 dB more max output below 30 Hz. Both the ISD and the dB-12 have VERY low distortion, but the TC unit beats the ISD by a few percent here.
    2) A 525W amp with a variable phase control, and a 4 position SS filter.
    3) Almost twice the port area.
    4) Adjustable tuning points using the factory supplied port plugs.
    Assuming the same size enclosure, both lines have a very similar sonic signature, and that is no mistake on SVS' part. The PCi is a VERY capable sub, and can embarrass just about any other commercial sub anywhere near it's price range. But when you factor in the significantly higher output capability with even lower THD, the variable phase and SS filters, and adjustable tuning points, the PC+ is a home run bargain for only about $200 more.
    SVS
