How to wall mount monitor 30's?
dh4645
dh4645 Posts: 61
edited August 2008 in Speakers
I am thinking of getting monitor 30's for my surrounds. How do you wall mount them?
I know they are supposed to be 2-3 ft above ear level when sitting, but are there brackets to buy or do you just use some sort of screw?
Thanks for the help
FYI, my room is approx 16' x 20' x 7'
Here is my current setup:
My entertainment setup:
Sony XBR9 52"
C - Polk CS1
F - 2 Polk Monitor 60's
S - 2 Polk Monitor 30's
SB - 2 Polk Monitor 30's
Sub - Polk PSW111
Onkyo 605 AVR
Scientific Atlanta DVR
Z-Line Vitoria Stand/Mount
PS3 and Xbox 360
Post edited by dh4645 on
  • VSchneider
    VSchneider Posts: 443
    edited August 2008
    You can buy additional brackets, such as B-Tech BT77, or the built-in keyhole slot.
  • dh4645
    dh4645 Posts: 61
    edited August 2008
    VSchneider wrote: »
    ok thanks a bunch.
    how do you use the keyhole slot if i don't want to buy 4 of those brackets?
    Sony XBR9 52"
    C - Polk CS1
    Sub - Polk PSW111
    Onkyo 605 AVR
    PS3 and Xbox 360
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2008
    Simply use the appropriate wall anchor, such as a wood screw, and slide it on.
  • dh4645
    dh4645 Posts: 61
    edited August 2008
    dorokusai wrote: »
    ok, thanks
    Sony XBR9 52"
    C - Polk CS1
    Sub - Polk PSW111
    Onkyo 605 AVR
    PS3 and Xbox 360
  • BjornB17
    BjornB17 Posts: 752
    edited August 2008
    hey there dh,
    He is correct. There is a little metal piece that is bolted on to the top of the monitor 30s that has a keyhole slot. Also there are rubber (or plastic?) stoppers on the bottom of the speakers. This keeps the speaker cabinet from scraping up the wall and gives in about an inch or so of separation from the back of the cabinet to the wall. This gives a little space for the port to breathe as well. If you get a long enough screw, you can have the screw protrude a bit out from the wall and this will allow you to angle the speaker down a little bit if needed.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
