amp/sub question
ROOGER82
ROOGER82 Posts: 30
edited September 2008 in Car Audio & Electronics
OK so i ordered a set of 10" DVC momo subs....but they had sent me the new DB subs. Called polk and they told me the Momo line is being replaced so those subs were the closest matching to the ones i ordered.
After getting refunded the difference. I now have a PA600.1 and 2 DB subs.
My problem is that the DB subs run at 250W RMS....and the amp i will be using runs at 600W...because i am bridging down to 1 ohm.
Is this too much for the subs?. Any suggestions on what I should do?
this is the last part of my audio system i need to finish...well besides putting the radio in.
(Insert clever sig here);)
Post edited by ROOGER82 on
  • exalted512
    exalted512 Posts: 10,735
    edited August 2008
    Where did you order them from?
    -Cody
  • ROOGER82
    ROOGER82 Posts: 30
    edited August 2008
    i ordered them form my polk audio accomodations from Circuit City. and there is a no return policy.
    I have no problem with the mix up....just hoping i dont blow the subs.
  • exalted512
    edited August 2008
    Did they give you any money back?
    You have 500w worth of subs on a 600w amp, you should be okay.
    -Cody
  • ROOGER82
    ROOGER82 Posts: 30
    edited August 2008
    ya they did give me money back....One more question.
    I am currently running the DB series components and the 6x9's. For the meantime untill i get the dough to get my doors fiberglassed I will be using those. Will the PA500.4 be too much power?
    I have never overpowered speakers before...just subs...so I dont know how these will be affected.
  • ROOGER82
    ROOGER82 Posts: 30
    ok so my trunk set up is done...will try and post pics tomorrow so u guys can judge it.
