To SACD, or not to SACD...
Jeff Beaird
Jeff Beaird Posts: 217
edited August 2008 in Electronics
Is it worth it to buy a new cd player w/SACD when your pre (Parasound p/sp 1500) doesn't support Digital. Will the difference be heard? I see the Pioneer Elite for $100 @Vann's. Really hard to pass up.
System; Parasound pre P/SP AV 1500
Adcom GFA-555 (LS90's)
Marantz MA500 mono's X 3 (Monitor 4's and CS350LS center)
Dayton sub amp (BFD Table Tuba) AWESOME..!
Thanks, Jeff...
Post edited by Jeff Beaird on
  • Danny Tse
    Danny Tse Posts: 5,206
    edited August 2008
    Generally, SACD is decoded by the player's internal DAC and output thru its analog outputs....therefore, if you amp/receiver has analog inputs, you are set. To take advantage of available multi-channel mixes on SACD, you'd need 5.1 analog inputs. On the Pioneer Elite DV-48AV that you're talking about, in addition to what I just described above, you can also output the native DSD datastream via its HDMI v1.2 output and decode the DSD datastream using a DSD compatible HT receiver. This way, one HDMI cable can transmit all the signal instead of having multiple analog interconnects.
    As for whether you should SACD or not, if you like the music selection available on SACD, then by all means. Check sa-cd.net to see if your favorite music is on SACD. Keep in mind that SACD is now basically only available online and hard to find at brick-and-mortar retailers.
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2008
    Another thing I'd like to add is that all SACD's have a 2-channel layer on them, which is what I always listen to. So even if you do not want/need 5.1 you might be able to benefit from SACD. It does depend on the quality of the player and of the rest of the system, but I personally enjoy them.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • schwarcw
    schwarcw Posts: 7,360
    edited August 2008
    Many listeners prefer the 2 channel SACD. SACD outputs analog so your pre is fine.
    Carl
  • Jeff Beaird
    edited August 2008
    Thanks for your replies, I am trying to make up my mind to invest in vinyl or SACD's... I'm definitely leaning SACD.
    Thanks, Jeff...
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2008
    I love my SACDs. In fact, they sound so good I have a hard listening to regular CDs.
    However, that problem is solved. Last week, I installed a DAC1, and this thing rocks. It makes CDs sound as good as SACDs. I did an A/B comparison between 2 channel SACD, and the CD version through the DAC1, and they sound the same. The same with regular CDs. They sound like SACDs.
    Its the best $975 I have spent on music. This thing works so great all you need is a dirt cheap CD player that outputs a perfect bit stream from the CD, and the DAC1 does the rest.
    http://www.sweetwater.com/store/detail/DAC1/
    And I will put in a plug for this company. About an hour after I placed the order they called to verify everything, and shipped it right out. When I opened the box they had thrown in some candy as a gift.
    I loved this thing so much I ordered a DAC1Pre for the living room. Its time to bring the SDA2s back to life.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2008
    I have to disagree with BlueFox; I, too, have a DAC-1, and it is GREAT, but it will NOT make regular CDs sound like SACD....you have to start with the source material. PLus, you have the option of 5.1 on SACD, and if you've never heard DSOTM 30th Anniversary remaster in 5.1, you're missing something.
    I have both a Sony cheapo & an Oppo 981HD for SACD; love 'em!
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
