Cost effective alternatives to dual LPA-1s?
BjornB17
BjornB17 Posts: 752
edited August 2008 in Electronics
Im thinking about buying 2 7.1 amplifiers and have been eyeballing the UPA-7 and LPA-1. the LPA-1 costs about $200 cheaper for each one so if I can obtain 2 i may go that route. Are there any other amplifiers out there of equivalent power and quality for around the same price ($450 per amp)?
Thanks!
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
  • jwhitakr
    jwhitakr Posts: 568
    edited August 2008
    Have you listened to your speakers with a solid amp such as the LPA-1 or equivalent from a good manufacturer? (Parasound, Rotel, NAD, Adcom, etc.)
    I think you'll find plenty of power with those amps, and would suggest you at least see how you like the sound with a good quality amp first. If you aren't satisfied, then you can go all out with dual amps and bi-amp to your hearts desire.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
