Sony CDP-CX455 owners
del44
del44 Posts: 686
edited August 2008 in 2 Channel Audio
Just picked up one of these. I have a question regarding changing discs in this player. When I go from one disc to another, the player makes clicking type of sound about 10 times and the blue light inside blinks. It does this after the last disc and then again, before the next disc. Is this a normal operation? Thanks.
Post edited by del44 on
  • joeparaski
    joeparaski Posts: 1,865
    edited August 2008
    Hmmm....I have 2 of these machines and I can't say that I hear a "clicking" sound. Basically when you select a disc, the carrousel advances to the disc location (whirring sound) then makes a sound when it pulls the disc from the tray.
    Is your unit working ok despite the clicking sound?
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • del44
    del44 Posts: 686
    edited August 2008
    It seems to work fine otherwise. Does you blue light blink while changing discs? Maybe 10 times when it's putting one disc back and then another 10 times when picking out the next disc?
  • joeparaski
    edited August 2008
    Yes, the blue light blinks until the disc is selected. I bought one of the units brand new at a Sony store and the other from a local guy, so I know that this is correct.
    Joe
  • del44
    del44 Posts: 686
    edited August 2008
    OK. Thanks Joe.
