Sdaii
leroyjr1
leroyjr1 Posts: 8,785
edited August 2008 in Vintage Speakers
What are you guys thoughts on the SDA II speakers?
Any good? What are they worth paying for?
Post edited by leroyjr1 on
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    Which one?
    Ben
  • leroyjr1
    edited August 2008
    The first ones with 3 mids and two tweeters. I think they're the first version
  • leroyjr1
    edited August 2008
    But are they any good ?
  • ben62670
    edited August 2008
    There are better ones. I personally don't care much for the dimensional tweeter. They are however a pretty good SDA considering that they are first generation, and one of the cheaper models. I had them they were real fun, but I moved on.
    Ben
    Ben
  • leroyjr1
    edited August 2008
    What would you recommend as far as sda's for a 24x16 room. I would like to get the big boys 1.2tl and 2.3 but my budget for my fronts are only $800 bucks.
    I will be swapping my lsi 9's and hopely SDA's on my 2 channel rig
  • ben62670
    edited August 2008
    1B's/1C's, or SRS-2's. Either of these can fill a room. You might be able to pull off 2.3's, or 3.1's. IMHO the SRS-2 have the widest sound stage, 2.3's/1's , and then 3.1's.
    Ben
    Ben
  • leroyjr1
    edited August 2008
    Thanks alot. I just wanted to add BEN you are very helpful to us new guys
  • ben62670
    edited August 2008
    leroyjr1 wrote: »
    Pfffft
    I heard that I am an A$$HOLE:eek:
    Ben
    Ben
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2008
    I have first generation sda2's. I disconnected the dimensional tweeter and it made a world of difference.
    The other generations did this from the factory.
    I think the first gen has more bottom end than the others though. Makes sense since it has 3 mids instead of 2.
  • leroyjr1
    edited August 2008
    GetAttachment.aspx?tnail=1&messageId=86e0368c-4b7f-411a-bcfd-e8aa4d56848d&Aux=44|0|8CAD1E671AE2F20|
    GetAttachment.aspx?tnail=0&messageId=86e0368c-4b7f-411a-bcfd-e8aa4d56848d&Aux=44|0|8CAD1E671AE2F20|
    GetAttachment.aspx?tnail=2&messageId=86e0368c-4b7f-411a-bcfd-e8aa4d56848d&Aux=44|0|8CAD1E671AE2F20|
  • Ron Temple
    Ron Temple Posts: 3,212
    edited August 2008
    Whatever you can get away with. I paid $100 for some 2Bs that aren't in bad shape but need some TLC. I don't think I'd offer more than $150 for 2s in great shape.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • nadams
    nadams Posts: 5,877
    edited August 2008
    Not to sidetrack the thread here, but would you guys recommend disconnecting the dimensional tweeter? As was pointed out, the 2a's and 2b's only had one tweeter.
    Actually, I seem to remember that Matt Polk himself preferred the later 2's over most other SDA's because they were the perfect configuration. One tweeter, one stereo driver, and one dimensional driver, in the perfect arrangement. The only problem with them is that they don't dig real low, and don't have the volume of the bigger SDAs.
    Ludicrous gibs!
  • ben62670
    edited August 2008
    nadams wrote: »
    YES! The high frequencies were all over the place in my first gen SDA2's. Just unplug one wire on the dim tweeter, and see how you like it. It will be a few DB down on the highs, but it gives you a real good idea of how it will sound. If you like it you may want to change the resistor in series with the stereo tweeter from 4 to 2.7ohms to bring the highs back up. No biggy. Let me know if you need any help.
    Ben
    Ben
