Center + Sub question.
millerman 3732
If I where to add a sub to my center channel using the line level inputs, would this create a phase issue with my main sub hooked up through the LFE channel?
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Post edited by millerman 3732 on
Why on earth would you do that?My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
I wouldn't do it and why do you want to do that.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Somebody is bored?
BillMy 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012 -
Still trying to get Batman to growl.
if you don't know what I'm talking about here's the link.
http://www.polkaudio.com/forums/showthread.php?t=70358Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Polk Signa-1 Surround bar -
How about setting your Center as "None" and seeing if the fronts/sub can then give you what you're looking for? If it does, then you know it's something about your center not reproducing the lows well enough. If it doesn't then it's probably not in the recording or the player isn't outputting it properly?Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
The problem is that I'm looking for something that isn't there, and as bsoko2 said, I was pretty bored when I tried this.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Does anyone have the CS1000p center channel..? If you are looking for low frequencies coming out of the center... this would be my first choice.
Anyone have one AND the Batman movie..? Do they hear the growl,grunt noises..?
Just trying to help...Thanks, Jeff... -
I have found that some material sounds better with a bass connected with the center and some you just can't listen too. If you do it remember to re caclibrate your system. Good luck. Have fun.Reciver Pre/Pro - H/K AVR-347
Amplifier - Adcom-7400 5 Channel
Speakers - SRT's
Projector - Sony Avl-aw15
