what would cause this?
POLKOROLLA
POLKOROLLA Posts: 74
edited August 2008 in Car Audio & Electronics
i put a profile ap2000 amp in for a guy - i know i know - profile - anyway - the thing worked great for a day - then it popped all the fuses and started kinda smokin - so he unhooked everything
now it smokes and pops the fuses everytime you put power to it
Post edited by POLKOROLLA on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited August 2008
    A ground loop your 12v wire is touching ground "I would check were it comes threw the fire wall". Or the ground wire is touching 12v wire. The first one is what I would think is going on. But Check all power wires.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2008
    First off, nothing wrong at all with Profile. They are probably the best entry level brand of amps on the market.
    Second, as mentioned, its likely a wiring problem. Something is shorting out somewhere.
  • POLKOROLLA
    edited August 2008
    could a bad ground also cause it?
  • exalted512
    exalted512 Posts: 10,734
    edited August 2008
    Its possible.
    -Cody
  • POLKOROLLA
    edited August 2008
    alright - so all the wiring looks good - the ground wire was a little loose - so i tightened that - everything was working great after the initial install - then the guy turned everything up - gain and boost - the the amp blew all the fuses and smoked...
    now everytime i put power to it the fuses blow - do you guys think the amp is fried???
    i am going to move the amp to my car on my wiring and see how it does - i am still a little scared to move my amp to his car in case i did miss something in his car
  • bigaudiofanatic
    edited August 2008
    It is blowing fuses because there is a ground loop some were. Also were are they being blown the amp or on the in line fuse under thee hood?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • exalted512
    edited August 2008
    my take is a fried amp.
    -Cody
  • POLKOROLLA
    edited August 2008
    the fuses are being blown on the amp itself - all four 25 amp fuses - under the hood is still fine - i will install the amp in my car today - we'll see how that does
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2008
    Just a guess here -
    Maybe something is shorted inside the amp?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • zingo
    zingo Posts: 11,258
    edited August 2008
    Do you have the opportunity to get a new unit? That might be your best bet as smoke is never good.
  • pjtime
    pjtime Posts: 19
    edited August 2008
    had the same problem with an oldschool mtx blue thunder amp. I let my friend boprrow it got it back and it did the same thing your talking about. It was the amp that was fried some caps inside actually popped.
  • POLKOROLLA
    edited August 2008
    i sent in the form to millionbuy.com for a return authorization - hopefully everything will go alright with the return - if not it's his money not mine - he should have left it alone
