recommend a good Sub to go with my Lsi9s
kkennally
Please help recommend a good Sub to go with my Lsi9s.
I am looking for a quality sub to be used with a 2 channel music only system.
I have a small to medium sized room and a budget from $400-700 for the Sub.
My system consists of:
Cambridge Audio Azur 740A integrated amp
Cambridge Audio Azur 640C V2 CD player
2 Lsi9s on epos 35st stands sitting on top of 3 granite plinths
Looking at Polk pro, Velodyne, Martin Logan dynamo
Music room: Cambridge Audio 650A, Cambridge Audio 650C, Polk Audio Lsi9's, Audioquest type 4 and diamond back.
Living room:Onkyo Amp ,Onkyo DX-C390, Polk Audio RTi6's, Polk Audio PSW505
Post edited by kkennally on
Used Velo SPL series."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I second that.
Or if you can, a good DIY sub will be an excellent value for the money.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Would the PSW1000 (Lsi) Sub be worth waiting for and spending the extra money for? Would they go better with the Lsi9s?Music room: Cambridge Audio 650A, Cambridge Audio 650C, Polk Audio Lsi9's, Audioquest type 4 and diamond back.
Living room:Onkyo Amp ,Onkyo DX-C390, Polk Audio RTi6's, Polk Audio PSW505 -
Check out Epik as well.Shoot the jumper.....................BALLIN.............!!!!!
From everyone I've talked with tells me the Epik Valor at $550 is the best bargain for a sealed sub for music (with high output for HT). 18hz with plenty of midbass slam, but stops on a dime. Married to the 9s, I think it would work well.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Well, it looks like I am going with the Martin Logan. The local tweeter has them for $599.00
ThanksMusic room: Cambridge Audio 650A, Cambridge Audio 650C, Polk Audio Lsi9's, Audioquest type 4 and diamond back.
for that price I'd go
http://www.epiksubwoofers.com/KnightSpecifications.html
http://www.epiksubwoofers.com/CaliberOverview.htmlShoot the jumper.....................BALLIN.............!!!!!
Personally I would wait a little longer until you can afford a little more especially with your current setup. You have such a nice setup!!!
I listened to a ton of subs and felt that I needed to spend a little more for my needs....and boy I'm glad I did. My sub is so tight, clean and the perfect addition for my setup.
http://www.snellacoustics.com/ProductDetails/3472.aspLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Thanks for the help.
System with the Martin Logan installed.
K.
Looks very nice....and I probably would have went with that sub if I saw your setup before I commented....very clean and spacious.
So how does it sound?Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Try the Polk audio , i have one of these.
● Driver: 12" Front-Firing; Slot-Loaded
● Amplifier: 300 Watts RMS
● MFR: 23 Hz - 160 Hz
● Low-Pass Adjustment: 60 Hz - 120 Hz, 4th
Order
● Inputs: Speaker-Level, Line-Level
● Outputs: Speaker-Level
● Dimensions: 16-18" H x 15-1/8" W x 18-3/16" D
● Weight: 40 Pounds
● MSRP: $589.99 USA -
No offense, but IMO that sub isn't in the same class as the Martin Logan (musically)Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
K.
So how does it sound to you?____________________
Pool: Atrium 60's/45's
