Multi Room LSi setup question
lhbrennan
I own a pair of LSi9's, and I'm powering them with an Emotiva XPA-5. I want another pair of LSi9's for the adjacent room. I will usually be toggling between the two rooms, so I don't think more amplification is necessary. I'm wondering what type of processor/receiver I'm going to need. Should I just buy to separate processors, then hook up both sets of pre-outs to the amp? Or is there a quality single unit I could buy that would take car of this? Any suggestions? Also, because we leave the sliding door between the two rooms open, I'm hoping I can get away with using the same sub for both rooms.
Thanks for any and all advice.
Post edited by lhbrennan on
Looking at the Emotiva MMC-1, it has stereo and Zone 2 pre-outs, so I assume other pre/pro's do as well. Just put a couple of XPA-5 channels on each and you should be fine.
Contact them with any questions.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
You definitely don't need more than one processor for this. Just make sure the receiver or pre you are planning on using has a second zone. I use my Marantz for exactly this. I have a 5.1 channel in my movie room, and it also controls 4 speakers and a TV in the adjacent game room (although I do have separate amplification).
It will be a bit trickier sharing the same sub unless you are driving both zones at the same time (which is what I often do). When I drive the game room, I just do it without a sub.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Thanks for the replies. It looks like the MMC-1 or something similar will work fine. I was a bit confused because I own a Marantz SR5002, and it has "multi-room" capabilities, but it only has one set of preouts, so unless I wanted to drive one set of speakers straight from the receiver, I couldn't figure out how to get it done. Hockeyboy, does your Marantz have zone 2 pre-outs?
My SR8001 only has a single set of pre-outs like the SR5002. I use two of the pre-outs to connect to a separate Sunfire 5200 in the game room, with the other 6 pre-outs being used in my theater. The game room gets a signal for front and back with a volume control in the wall for each pair. Each speaker get their own channel on the 5200 for power but share a signal with their neighboring speaker from the Marantz in zone 2. I mapped it out and my installer actually did the connections.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
That's interesting. I can't really visualize how you could send a signal to four speakers using only two pre-outs. Wouldn't the sound be only one sided?... as in zone 2 has two left front speakers and two left rear speakers? Maybe I'm just confused; I'm new to this stuff.
What they're talking about is two sets of pre-outs. One set for one zone and another set for another zone.
Chris -
Ron Temple wrote: »Looking at the Emotiva MMC-1, it has stereo and Zone 2 pre-outs, so I assume other pre/pro's do as well. Just put a couple of XPA-5 channels on each and you should be fine.
I use the MMC-1 For that very purpose.It works great.
