Watts
Systems
Systems Posts: 14,873
edited January 2003 in Car Audio & Electronics
What is the difference between peak and continuous watts?
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2003
    Peak refers to instantaneous split second performance.
    RMS or continuous refers to just that -- constant power handling.
    Referring to an amp -- peak power is the amount of power you will get out of the amp if you're going to "burp" it for a moment and get every bit of juice out of it. Constant / RMS is what it'll put out every day while you're driving around.
    Same goes for a subwoofer -- peak or max is what it'll take for just a brief moment... rms/constant is what it'll take for hours on end.
    The Artist formerly known as PoweredByDodge
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited January 2003
    peak is next to useless to know
    be wary
    if it says 1200 peak it can only play around 500-600 continuous
    when you buy amps/speakers look at the continuous
    peak is put on the box to sell it
    well not completely
    but mostly
    -Cody
