RTi10s
hydrostream
Up until last week my setup was a Adcom GTP-500II and a GFA-555II
powering my RTi10s and a GFA-545 powering my RTi8s. I sold my 8s
and now just running my 10s with the 555 and when i crank it up the
mid-woofers go crazy they look like there going to jump out and can
hear them distort.
I never had that with the other setup. I'm going to try the 545 amp
with the 10s and see what happens. Or should i try to Bi-amp with
the two amps? Use the 545 for the top and the 555 for the woofers.
Need to know if the top connectors are for the tweeter and mid.
thanks jerry
hear them distort.
thanks jerry
Main- GTP-500II,GDC-600,GFA-555II and energy C-500s
Basement-Audiosource pre/tuner,GFA-545,Onkyo
DX-1400 and RTI10s
Garage-GTP-450,onkyo M-282 and R50s with RTi55
drivers and X-overs.
My baby 18' V-king Mod VP with a merc 2.4 BP.
KTM 620 Supermoto
DX-1400 and RTI10s
KTM 620 Supermoto
Post edited by hydrostream on
If your are hearing them distort with one amp and you are interested in adding another amp, then I'd be careful with not cranking it up to distortion levels. Top posts are for the tweeter/mids and the bottom for the 2 woofers.
Well if i bi-amp the mid and tweeter would be getting powered
by the 545 a little less power.
jerryMain- GTP-500II,GDC-600,GFA-555II and energy C-500s
DX-1400 and RTI10s
KTM 620 Supermoto -
trying the 545 amp is not a bad idea , i have my friend using it , i heard it is a little more expensive than the similar items , but it has feature like the bias trimpot.
I think i found the problem it looks like the cone is not attached
to that brown wavey material. Can that be re-glued?
I'm trying to post pics but it not reading the camera.
Looks like the glue came apart and the cone moves without
any suspension.
thanks jerryMain- GTP-500II,GDC-600,GFA-555II and energy C-500s
DX-1400 and RTI10s
KTM 620 Supermoto -
How loud were you playing them? If you were hitting 110dbs, you might have clipped and blown the driver, though I'd think the tweeter would have gone first.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Here are some pics.
DX-1400 and RTI10s
KTM 620 Supermoto
