Office 2003 installation help
audiobliss
audiobliss Posts: 12,518
edited August 2008 in The Clubhouse
I have two sets of Office 2003 discs, each good for two installs. I used ONE of them on my laptop, and I have no recollection of which one I used. Well, I ended up adding a user to my laptop and deleting my old account, and now I get an error when I open Office, so I was just going to reinstall it.
However, how do I know which product key to use? Does it matter? I'm pretty sure I've installed both of them twice, so I would think I need to use the same one again. How can I find out, or can I?
Thanks!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2008
    audiobliss wrote: »
    Thanks!
    I'm not sure if this may help, but what I do is try to install on another machine and see if it activates. If it doesn't, I know that I already used the disc two times.
    What get me upset is that when buying a laptop, I had returned one to the store and bought another one. That counted for 2 installs. Now I can't install Office on a PC that I want to anymore.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • petrym
    petrym Posts: 1,912
    edited August 2008
    Install it and activate the installation, if it activates, you're okay. Iif it doesn't activate, call the tech support number and explain the situation, if you tell them what the deal is, they'll allow the installation and you'll be legal.
  • audiobliss
    edited August 2008
    petrym wrote: »
    Awesome info. Thanks. :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Serendipity
    edited August 2008
    petrym wrote: »
    Wait - so if in my case I buy a laptop and then return it, and then buy a *totally different* brand laptop, I can still install Office one more time?
    When I did this the Activation wizard told me that I had exceeded the maximum number of installs. But I had only used it once, the second one was on the laptop that I returned to the store.
  • petrym
    petrym Posts: 1,912
    edited August 2008
    appadv wrote: »
    You'd have to uninstall it before you return it. Again, explain it to the tech support software **** if there are any problems with activation. ;)
  • Serendipity
    edited August 2008
    Uninstall Office before I return the laptop? Or the software?
    I've gotten by with returning the Office CD to the store once, but they told me usually you can't return software. They made an exception for me and let me exchange the disc.
  • Serendipity
    edited August 2008
    petrym wrote: »
    That didn't work, Microsoft basically said that if you had this issue you should've contacted them or uninstalled first. They also said the same thing about my Windows Live OneCare, I installed it on a machine that sat in storage for 8 months and when I went back to reactivate it, I couldn't get the remaining of the subscription that I paid for.
    This is even more annoying than Office, as the OneCare subscription starts the first time you install it on a PC. So if your machine breaks and you return it to the store, the next time you install it you're on the *second use* and that subscription isn't going to last you a year.
  • exalted512
    exalted512 Posts: 10,735
    edited August 2008
    So I have one copy of office 07 I cant put it on my laptop and my desktop?
    I know someone who put one office 2003 on his laptop and his desktop without any problems?
    -Cody
  • Serendipity
    edited August 2008
    exalted512 wrote: »
    -Cody
    You can do that, as the license allows for two installations (at least for the retail version).
    The issue is if you were to buy a laptop, return it to the store, and then exchange for another laptop. That would count as 2 installations even though you only have one laptop.
  • exalted512
    edited August 2008
    got ya!
    -Cody
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited August 2008
    appadv wrote: »
    Activation is a joke. Call them and tell them that you are re-installing, when they ask why, tell them it was due to a hardrive failure, or some other repair. They will re-activate every time. This works for XP and Office.
    I am NOT suggesting anyone do this for illegitimate reasons.
  • Serendipity
    edited August 2008
    WilliamM2 wrote: »
    This didn't work for me, and I have the retail (boxed) version of Office 2003. Same thing with OneCare - they said 1 year of virus updates starts from the FIRST time you use it, and they don't care if you returned a laptop to the store and exchanged it for a new one.
    The lady on the phone said I had to call MS then, they can't do it a year later.
  • WilliamM2
    edited August 2008
    If didn't work for you, then you are answering some of their questions wrong.
    I also have retail versions of both XP and Office 2003. I have built a new computer 3 or 4 times since buying each of them, the last time was just a month ago. I have never been denied reactivation.
    How many computers is this currently installed on:
    One
    Is this the first time you have activated:
    No
    Why are you re-activating:
    Hard drive failure
    Every answer I give is true, except the last one. I find that if you try and describe any other reason , it's too much for them to understand.
  • Serendipity
    edited August 2008
    I've been telling them the truth, that I bought and returned a laptop with their software on it.
  • WilliamM2
    edited August 2008
    appadv wrote: »
    Which to their thinking, means that it is on too many computers, but it isn't. Of course in reality, you should have uninstalled it before returning the laptop. You have a legal license, try again, and use the answers I stated above. like I said, I am not advocating anything illegal, my copies really are only on one computer, but when you give them the full story, it's more than they can deal with apparently.
    Activation is just a pain for legitimate users, it doesn't stop pirates at all. I know people that have installed the same copy on dozens of machines, without any hacks or other nonsense. They just lie when they call.
  • Serendipity
    edited August 2008
    WilliamM2 wrote: »
    Isn't that unethical though?
    I bought a retail copy of the software so I should be able to install it on 2 PC's. Activation is just a pain really.
  • audiobliss
    edited August 2008
    He said they lie. I'm pretty sure that implies unethical.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • WilliamM2
    edited August 2008
    appadv wrote: »
    Of course that is unethical, and illegal. Like I said, I am not advocating anyone do that. Just telling you how it works.
    But you have a legal copy. Is it ethical for them to not let you use it.
  • Serendipity
    edited August 2008
    WilliamM2 wrote: »
    Yeah, I agree. I should be allowed another install.
  • Serendipity
    edited August 2008
    Okay, it worked. Now I have a copy of Office on my laptop and on my desktop.
    Thanks!
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2008
    There's nothing unethical about getting around the copy protection IF you purchased and paid for the product and can't get it to work like it is licensed to work. Tech support can sometimes be helpful, they can also sometimes be a bunch of bumbling fools.
  • Serendipity
    edited August 2008
    bobman1235 wrote: »
    Yeah, I just told them that my computer died and I'm reinstalling due to the hardware failure. Worked like a charm.
  • petrym
    petrym Posts: 1,912
    edited August 2008
    Hardware failure works everytime... just tell them your Hard Drive is clicking a couple of times a second. ;)
  • Serendipity
    edited August 2008
    petrym wrote: »
    So audiobliss, did this work for you?
  • audiobliss
    edited August 2008
    I didn't need to. I reinstalled it with my product key just fine.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • mmadden28
    mmadden28 Posts: 4,283
    edited August 2008
    WilliamM2 wrote: »
    Shouldn't matter whether its uninstalled or not. No retailer will resell a computer without reimaging the drive at the very least-there is simply too much risk of malware being on that system or other software anomalies. Its likely also that the retailer will simply RTV it, and again, no way-no how will any legitimate computer manuafacterer resell a system with a previous users data on it. MS should understand this-So in my opinion, reporting that the hard drive was dead does not hurt anything and is not illegal to do so in this case-some of the CS reps you deal with are literally working from a script, and really just don't get what happened-as WilliamM2 mentioned, it gets very difficult to explain. With a failed hard drive-its fairly certain that you couldn't uninstall and the CS rep will follow a different more streamlined script.
    You still legitimately and legally own the right of license-MS should be able to activate you with a code over the phone. I work with many computers that can't activate over the internet and have to deal with the convoluted codes and painstaking process all the time--have not had any problems yet (other than frustration and wasted time).
    Since you actually returned the computer, then you should have no problem providing proof to MS (such as a fax of the reciept).
    If they are unwilling to assist , return the copy of Office to the retailer as a defective copy, the manufacturers defect being that will not install / activate (tis the truth) and ask for an even exchange (not a return). If you have to, explain the situation to the store manager-any store manager with half a brain should be able to help (I've seen enough bogus returnes and CS fialings in my years, that this would be a no-brainer for good customer service.
    Personally I don't even use Office at home any more, or on any computers I build for friends. I use OpenOffice.org- for the price (free), and simple activation process (none required), it simply can't be beat.
    ____________________
    Pool: Atrium 60's/45's
  • mmadden28
    edited August 2008
    Sorry-didn't finish reading the posts-I see that your problem is resolevd.
  • audiobliss
    edited August 2008
    Yes, it is thankfully. But thanks for the input. :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
