2ch audio
Jason_k
Jason_k Posts: 110
edited August 2008 in 2 Channel Audio
This year I recently Bought a HT system. My signature shows the equipment I bought. Only thing is I like is fairly loud and in 2CH mode for music I find the 12's a bit bright. I was thinking with the Denon I have to make my below setup for movies only and take the Rotel Amp for Zone 2 for music on my denon(haven't taken a hard look at this for the denon, seems to do able though), so my question is I have around 2G's for a set of fronts for music, I live in newfoundland Canada and I have no wear to go to demo high end speakers, So I usually have to go on-line and hear reviews and so on(better bad hey). I was think the LSI 15's(not limited to these) for fonts in 2ch, I hear alot of good things about them for music and my Rotel should power them with no problems! any one have a similar setup or advice(besides selling my speakers I have bought)
Post edited by Jason_k on
  • Lowell_M
    Lowell_M Posts: 1,660
    edited August 2008
    I think that sounds like a fine idea. I have heard RTi12's in HT and think they are fantastic, but really, in 2-channel, the brightness hurts my ears. LSi15's on your zone 2 powered by your Rotel amp may be a fine way to go and you should be able to do it for quite a bit less than your budget if you go used.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • schwarcw
    schwarcw Posts: 7,358
    edited August 2008
    The LSi9's also sound very good if you are looking for a monitor size speaker. The new RTiA series is getting good musical reviews. There was a writeup in this month's Stereophile. Check out the review in the magazine. Good luck!
    Carl
  • Jason_k
    Jason_k Posts: 110
    edited August 2008
    Well I'am pretty much sold on the LSi 15's, anyone know about buying from polk direct with all extra's(i.e free shipping) applies to Canada residents?
  • Face
    Face Posts: 14,340
    edited August 2008
    schwarcw wrote: »
    Don't the RTiA's have similar voicing to the RTi's?
  • Jason_k
    Jason_k Posts: 110
    edited August 2008
    Just wondering if its possible to change the tweeters in the rti12's? one thats not so bright, any body have any experience with this?
    treitz3 Posts: 20,119
    edited August 2008
    Jason, as far as I know there is not a replacement. Those speakers were designed for an HT application and for what they were designed for, they do well.
    You might want to try adding a resistor in line with the positive terminal to help tame the tweeter down.
