Help Please Noob Question
mikey0013
I guys i just finished setting up my speakers my question is this what should my frequency be set at on my subs. My setup consists of M50(fronts), 4M10 (surround), csm(center) 2 psw 111 (subs) with a Sony str-dg 910 amp. ALL SPEAKERS ARE SET TO SMALL
Thank You
Thank You
Post edited by mikey0013 on
how does it sound with those settings?
have you run your Sony's auto calibration for the speakers?
I think your fronts you could run on large...PolkFest 2012, who's going>?
i have ran the auto cal on the reciever it set everything to small but the fronts, i set the fronts so small so it wouldnt work on the lows so much (if that makes sence), the setup sounds good but i feel that the bass is to deep is that controlled by the crossover?.
yes the bass on the speakers is also controlled by the crossover.. you can try say 80 on the crossover and see how it sounds... or 90, or 100PolkFest 2012, who's going>?
I would set the fronts as large and keep your crossover around 60hz. You can try to go higher, however IMO, there is nothing worse sounding than a sub that plays too high (hz).Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
M50s should be set to small. What's the -3db 57hz? Cut them at 80.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
thanks guys i think im gana keep the fronts to small and keep the crossover at 80 see if it sounds good thanks for the advice.
