preparing a poll on best CD players under 1k
Norm Apter
OK, so what I'd like to do is conduct a poll on best CDP that retail new for less than 1k (much like SteveinAz polls on interconnects and speakers cables)
But before I put the poll together, I'd like to compile a list of candidates. I will definately be putting these three in the list of contenders:
a) Rotel 1072
b) Cambridge Audio 640 v2
c) Rega Planet
Please let me know of other contenders that should be put into this poll. (I believe that I can have a total of up to 10 (???). SS and Tube (though I don't know if any tube players retail for less than 1k new) are both OK.
While I do plan to buy used eventually, I thought setting the new price perimeter at 1k or under was the easiest way to come up with a target list.
Norm
a) Rotel 1072
c) Rega Planet
Norm
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
HT
Denon 2808ci AVR
Post edited by Norm Apter on
You don't need no stink'in poll. Just buy a Jolida 100 CDP if you like playing with tubes, or a Rotel RCD-1072 if you don't.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Add the Rega Apollo to your list if the first post doesn't answer your question.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Onkyo DX-7555
Arcam CD73 is very good.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
What he said...... -
Ah! Njoe Toeb
Marantz (pick one)
NAD 541Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Marantz SA-8001."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Ah! 4000
Don't over think it; just go and buy something, used. Listen for a while, if you like it you keep it, if you don't you buy something else. The beauty of buying used is that you can sell for about the same, sometimes more._________________________________________________
+1 on the ArcamHT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
I would also add the Consonance cd120 linear in there as well. Just seems to do everything right by my ears. I prefer it over the jolida myself. It isn't as heavy a hitter as the jolida but it is much smoother and more amalogue sounding. It also has excellent separation of instruments for an inexpensive player.
Good luck,
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Jolida JD100 with EI Gold Pins.
You can play with the tubes to tailor the sound to compliment your equipment and or room.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Out of everything listed here, my choice would be coin toss between the Arcam and Rotel. Just my 2 cents.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
nikolas812 wrote: »what he said......
+1.........HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
Thanks for the responses thusfar. I'm still going to give a little more time for folks to chime in before I put it together. Maybe I don't really need a poll, as some have indicated, but I'm going to go ahead and make one so as to give as many people as possible the chance to give their input. Then, after voting, they can provide additional commentary, if they like (especially, they have directly compared any of the models on the list and what their impressions are).2 Ch.
HT
Denon 2808ci AVR
Signal Cable Analog II Interconnects -
Maybe you should do a poll to see which ones to include.
I'm not sure what I'd get but the Jolida would be high on the list.
Actually, you couldn't go wrong with anything listed thus far...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
