3 RTi8 vs CSi5 and 2x RTi10
If you guys had to make the following choise, which would you pick:
3x RTi8 for the front
OR
2x RTi10 and 1x CSi5 for front
In addition to that the 3x RTi8 would cost half of what the other option cost. What would you do?
The reason I ask is because I'm in this exact situation right now. Would an RTi8 as a center channel sound equivealent or better than a CSi5. Would the soundstage be better with 3xRTi8 in the front instead of 2 different types of speakers? Can RTi8s fille a 20x17 room (which opens up to the rest of the house) with plenty of volume?
Thanks!
OR
Thanks!
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
I think 2x RTi10 and 1x CSi5 would sound a little better. Have you thought about where you would put the RTi8 if you use it as a center channel? If you’re using it for home theatre you would need to put it right in front of your TV and the RTI8 is not exactly a small speaker.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
Subwoofer: Mirage Omni S10
TV: Sharp Aquos 42" 1080p LCD
Receiver: Onkyo TX-SR805
Blu-Ray Player / CD Player / DVD Player / Media Server / Game Console / Best money I've ever spent: 60GB PS3 -
i have 10 foot ceilings and a projection screen so plenty of clearance room
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780 -
In my opinion, I would take the RTi8's and get a good sub with the money you save. I think RTi8's + Sub = better then RTi10. And I've never used an RTi8 as a center but I imagine it would sound better then the CSi5.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
Do you consider there to be any major shortcomings with the Velodyne CHT-12 i have?KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Don't know. I've never heard the Velodyne CHT-12. Velodyne is a good brand though.7.1 HOME THEATER:
Center: CSi3
Front: RTi10
Surround: RTi A3
Rear Surround: RTi4
well since they CSi5 is already on the way, i decided to order a pair of RTi8s for the mains to replace my Monitor 70s.
Thanks for the help.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
