Nugent...
fossy
while thoroughly engaged in wonderful listening of cat scratch at 4 am....
one of the 7c's tweeter stopped cold in it's tracks.......
switched the tweeters( one has been replaced b4- one is stamped 1984-- the other 1994---8 ohm ) & it's not the tweet
:( damn crossover thingy !!!!
Guess I'll pull the lsi9's outta the closet till repairs are done to XO-- might need advice--- I can use a torch -- not sure about a soldering iron
:D
Post edited by fossy on
So no fuse eh? If not, sounds like a polyswitch? Not too bad replacing them,,I was going to suggest bypassing them, but if volumes are an issue you just may want to replace both of them and be safe--good luck.JC approves....he told me so. (F-1 nut)
Damn Nugent....started his career killing speakers....then when that died down he started killing every animal on the planet ( Hey, he eats them so its all good
) .....now he is back to killing speakers. A fully completed circle
The first rule of Fight Club is you don't talk about Fight Club -
Is he from China?
You should see some of his recipes, with the quote on top
" If I can kill it....I can grill it "
My 7C's are fused, it's a simple check.
If you've already checked the obvious, replacing a capacitor or resistor in Monitor 7's is pretty easy."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
It was the fuse --- duh -- i forgot all about those little sucka's ---
Mr. Nugent must be gettin older if can't even kill a little ole pair of 7c's
So in a tribute to ole Mr. Nugent --- -
Yes Ted has been know to blow speakers...LOL
But if you want to test a set of used speakers....try Zack Wylde..not Ozzy stuff, his own solo Cd's.
If there is a speaker thats close to blowing up...it will........LOL -
FYI: I wouldn't recommend blowing up your speakers.
