Can you catch a cold from being cold?
Serendipity
Serendipity Posts: 6,975
edited September 2008 in The Clubhouse
Possible stupid question, but...
I have a cold. I was told by an aunt yesterday that when you are exposed to cold weather, you are more susceptible for catching colds. I'm like BS - I thought colds were viruses and that you have to be in contact with the virus in order to get the cold. Meaning you can't get a cold by just being in cold weather or with wet hair/clothing/etc. But that's not what some think.
So what is the definitive answer?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • Demiurge
    Demiurge Posts: 10,874
    edited August 2008
    No.
    Thread over.
  • bobman1235
    bobman1235 Posts: 10,822
    edited August 2008
    What he said; no. The winter just happens to be cold season; I suppose it doesn't help that we're all cooped up inside so there's more opportunity to exchange the virus, but other than that there's no correlation.
  • ShinAce
    ShinAce Posts: 1,194
    edited August 2008
    Actually, yes.
    Virii normally infect the respiratory system by means of the sinus and throat. Cold air passes over these areas and they are cooler than body temp.
    Ever notice you get a fever(warmer) to fight the cold? Well, the virus likes colder body temps.
    There is a tiny bit of truth. However, you can be hypothermic and won't catch anything if a virus does not enter your system.
  • Demiurge
    edited August 2008
    Actually, no.
    Demiurge, MD.
  • bobman1235
    edited August 2008
    ShinAce wrote: »
    Actually, yes.
    Being in the cold doesn't lower your body temperature enough to make a difference, unless you are a lizard.
  • ShinAce
    edited August 2008
    The air passing through your throat is cooler, and that's the temp that matters, not body temp.
    Cold does not give you a cold, it just makes it easier.
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2008
    The only thing the cold does is wear you out faster as your body has to regulate your temperature more. Although you have to be pretty much drained before it can do anything but, this can act as a doorway to catch a cold because your body is less able to fight off a cold.
    But it doesn't cause a cold directly.
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    I live in Houston in the summer and Missouri in the fall/winter. Never have gotten a cold since being in Missouri with weeks of 5 degree temperature. Maybe I am Bruce Willis from Unbreakable... I don't know.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • DollarDave
    DollarDave Posts: 2,575
    edited August 2008
    Except here in Houston, almost all air you breath is colder than your body temp, so that augument doesn't fly. Viruses die at a certain low tempurature, I can't remember what it is, but it is like 35 degrees - at least that was the explanation my brother-in-law (doctor of infectious deseases) gave me for why diet coke cans don't purvey sicknesses as the lid is obviously exposed to all sorts of things.
    I have had more cold and flu in the 8 years living in the south than I ever had living in the north. Could be attributed to many things, but it sure seems correlated to me.
  • Demiurge
    edited August 2008
    Cold weather has nothing to do with illness. It's a matter of how viruses are spread from one person to the next. Being "cold" doesn't expose you anymore to viruses than being "warm."
    P.S. - If you haven't noticed, appadv, these are the types of questions you don't need Club Polk to answer. A simple search of Google (or your prefered search engine) would provide you a great deal of information proving this myth false by actual doctors who are far more qualified to answer these questions than anyone else. Y'know?
  • Early B.
    Early B. Posts: 7,900
    edited August 2008
    Well, all I know is -- whenever I catch a cold (usually in the winter), warmer temperatures amelioate it and colder temperatures exacerbate it.
    Some would argue that the reason people catch colds in the winter is because the viruses spread quicker since people are more likely to stay indoors. This is probably only partially true. The cold weather thing has some truth to it, as well.
    "God grooves with tubes."
  • Serendipity
    edited August 2008
    Demiurge wrote: »
    Yeah, I'm just too lazy most of the time.
  • Early B.
    edited August 2008
    Actual doctors? They're clueless. Yopu're better off asking your fellow Polkies. We know everything.
  • NotaSuv
    NotaSuv Posts: 3,860
    edited August 2008
    "P.S. - If you haven't noticed, appadv, these are the types of questions you don't need Club Polk to answer. A simple search of Google (or your prefered search engine) would provide you a great deal of information proving this myth false by actual doctors who are far more qualified to answer these questions than anyone else. Y'know?[/QUOT
    Now thats some funny chit using "actual doctors" and "qualified" in the same sentance
    thanks for my laugh of the day :D
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2008
  • bobman1235
    edited August 2008
    Early B. wrote: »
    Anecdotal evidence != science. Science - that is, you know, fact based on actual studies - shows pretty much without fail that outside temperature has nothing to do with the occurrence of the common cold. Staunchly insisting that research is false for no particular reason makes you like those morons at the Flat Earth society.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited August 2008
    Demiurge wrote: »
    No.
    Thread over.
    This was the last post necessary.
    Shizelbs, PharmD
  • suprafantx
    suprafantx Posts: 249
    edited August 2008
    Early B. wrote: »
    Yep, we Polkies will use woofer to make artificial heart. It is simple theory, bigger the woofer, the better blood flow.:):confused::D:)
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
  • AsSiMiLaTeD
    edited August 2008
    Shizelbs wrote: »
    Shizelbs, PharmD
    I was wondering when you'd weigh in...
  • Shizelbs
    edited August 2008
    I'm just pissed Demi beat me. I thought I got to handle the medical BS.
  • Demiurge
    edited August 2008
    Shizelbs wrote: »
    I haz gewgle!1!1
  • Shizelbs
    edited August 2008
    Yeah well my degree I cited actually exists.
    And don't type in lolspeak. You're better than that.
  • Demiurge
    edited August 2008
  • Shizelbs
    edited August 2008
    Glad we can agree on that.
    kthxbai
  • Demiurge
    edited August 2008
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    Its funny how a cold is called a "cold" in the winter and a sinus infection in the summer.
    We bundle up in the winter, thus generating more heat and litterally sweating, this could be the reason. So its not the cold, but the heat.
    ...hell I dont know. But we havent found a cure for it. And I just like to sneeze on people...:p
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited August 2008
    (Ujh&((^)&*^&%^*&)(#$#&%)&_%$&#$*
  • Shizelbs
    edited August 2008
    Colds and sinus infections are two different things, generally speaking.
  • steveinaz
    steveinaz Posts: 19,538
    edited August 2008
    Cold give you a cold?
    Nah, old wives-tale. Though cold air can lower your resistance to illness.
  • Demiurge
    edited August 2008
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/0O2aH4XLbto&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/0O2aH4XLbto&hl=en&fs=1&quot; type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
