Help Wall Mounting Panasonic
Paul in Canada
Paul in Canada Posts: 178
edited August 2008 in Electronics
I just got a new panasonic plasma and a wall mounting bracket. In the Panasonic instructions it doesn't show where to mount to the TV. It looks like you have to pop out a couple of plugs and that would be where the screws go but I just want to make sure thats where they go and what is the proper way to remove the plugs. Anyone out there with a panasonic have any advice.
Thank.
Polk RTi 8's
Polk CSi 5
FXIA4"s
Outlaw Audio M200 x2
Denon AVR 2805
Sony CDP C345
Paradigm PW2200 Sub
Panasonic 50"
"It's futile to have a battle of wits with an unarmed person." demaples July 29/08
Post edited by Paul in Canada on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2008
    If I remember correctly the plugs just pop out, you need something to get under the lip. A small pocket knife works great. Be cautious on the screws to use, as I remember like 3 or 4 sets of them didn't want to use a screw which was too long. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Systems
    Systems Posts: 14,872
    edited August 2008
    dj7 is correct,the plastic plugs just pop out.I cant remember the bolt size other than it was metric.
    Testing
    Testing
    Testing
  • Paul in Canada
    edited August 2008
    Thanks a lot guys. I didn' t want to take a chance that maybe I was going to do something stupid by poping those plugs out. I'm hoping to get this on the wall before bed so that it is safe from the kids while I'm at work tomorrow. Thanks again.
    Polk RTi 8's
    Polk CSi 5
    FXIA4"s
    Denon AVR 2805
    Sony CDP C345
    Paradigm PW2200 Sub
    Panasonic 50"
