Anybody who is interested...
wangotango68
just mounted them on my home made oak base. sound is surprizingly good!
scott:cool:
scott:cool:
Post edited by RyanC_Masimo on
scott:cool:
Looks like something gidrah did...hmmmDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
I'd like to do that with a couple vifa's.Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend -
yep he gave me the idea. make sure they are full range speakers,
scott:cool: -
Feel like I'm in a Blue Man Group show.....do you bang the tubes with drumsticks at all?????
Peace StuffMDYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube -
they filled our living room with sound. for a little 4 inch driver they have a nice bass responce.
scott:cool: -
Ya know, that just looks so odd. No offense
Must be a great converation piece, how does it sound?The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
parts experss has a slae on 4 in drivers 90cents each. were thoes old parts that you took out of a re modle lol. nice use of a flange for the base.
Audionutt was going to build a pair also.;)
I hope you like them. Have you used any stuffing? I haven't yet, but probably will when I get a chance. If you like the sound of these but feel it could be better, you could probably replace them with Fostex FE-103 (I think). There are also tweaks like felt on the driver side of the basket and using epoxy or plumbers putty to solidify the magnet to the basket. There's also stuff you can do to the dust cap and cone. I couldn't tell by the pic, but if they have whizzers, you can use a piece of foam insulating strip between the whizzer and cone.
They have better bass in corners (of course), and 6ft apart. The driver is a tad high. One of these days I'll corkscrew some of that straight tube and offset with stands if need be. I'm quite impressed with the off-axis. The sound travels well into my other rooms without having to crank it up.
Let me guess, the image like there's no tomorrow.Make it Funky! -
There's also the front baffle. Mine is ugly compared to yours. I asked around as to the need of the front baffle; as I wanted to trim mine close, I gather that that the need is there. Something about beaming at a freq. that is within the sensitive hearing range. I'll put a teardrop shaped baffle on the front (to disperse the freq. of the reflected wave), when I can get some time and borrow a router.Make it Funky!
the driver is mounted to a small piece of 4 inch pipe that is cemented into the 4 inch elbow end. i had some stuffing in them but to me it sounds better without it. the wires stick out of a little hole that is drilled at the bottom of the flange. hopefully ill get some binding post to mount there.
scott -
