Removed Sonicap bypass caps from SDA's
Stew
Stew Posts: 645
edited June 2009 in Vintage Speakers
I just removed the 0.1 uF Sonicap GenII bypass caps from my SDA 2B-TL's and I like what I'm hearing - or rather what I'm not hearing.
When I upgraded my crossovers several years ago, I had all solid state equipment and a smaller room that was less bright and more bass heavy than our new basement. Jeff at Sonicraft recommended the bypass caps for a solid state system but said it may sound better without them in a tube system. I tried it with and without the bypasses and preferred them for that system in that room.
Since then I've added a tube buffer and moved to a new house with a much more reflective basement. I built some acoustic panels for the top corners and they help a great deal. The SDA's still sounded annoyingly bright at times though.
I finally took F1 and Raife's advice and removed the bypasses. In hindsight, I should have done so when I added the tube buffer. The detail is all still there but it sounds more natural. I'm also noticing that I can play them considerably louder without fatigue now.
SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605
Post edited by Stew on
  • ben62670
    ben62670 Posts: 15,969
    edited August 2008
    Glad to hear you are liking what you hear. I did away with the bypass in all my Polk's;)
    Ben
  • schwarcw
    schwarcw Posts: 7,341
    edited August 2008
    Thanks for sharing your experience Stew!
    Carl
  • nspindel
    nspindel Posts: 5,343
    edited August 2008
    I've Sonicap'ed two pairs of SDA's so far, neither with bypass caps. I'm definitely not feeling like I'm missing anything. I should mention that I run a tube preamp.
  • Ricardo
    Ricardo Posts: 10,636
    edited August 2008
    Good stuff. My CRS+ have around 40 hours with their new Sonicaps, no bypass, no polyswitches. Sounding gooooood.
    SOPA
  • zingo
    zingo Posts: 11,258
    edited August 2008
    Ricardo wrote: »
    I have that combination too, plus RDO-TL, and it does sound goooooood. I'm glad you dropped the bypass Stew. :)
  • Stew
    Stew Posts: 645
    edited August 2008
    Ricardo and Zingo - Agreed! My 2B's are running the TL mod with RD0198-1's, Sonicaps, no bypasses, no polyswitch. I still had the polyswitches in when I first removed the bypass. The sound was more natural but I missed some of the sparkle and detail. Removing the polyswitch brought back the sparkle and detail yet retained the more natural sound. Mids and highs just sound more real now. I've had that "you are there" sound with female voices since I did the TL modification but male voice were never quite right. They are now! Cymbals etc. were kind of "in your face" with the bypass caps but now they're in proper perspective.
    On a side note, I measured before I removed the polyswitches and the resistance was only about 0.2 to 0.3 ohms. I doubt that's enough to make much of a difference so there must be another reason. I'm not sure what they're made of but they do muffle the sound. I've only tripped the polyswitches one or two times in their 19 year existence and that was about 19 years ago with a lesser amplifier. I'm not too worried about removing them.
    1000VA Dreadnought
  • zingo
    zingo Posts: 11,258
    edited August 2008
    I removed the polys in my 4.1TLs and Monitor 5Jrs and liked the results of both. I realized that I'm not going to blow up my speakers with an under powered amp or turning it up too loud, so why have another component in the signal path? Thanks for the poly info and enjoy the listening.
  • Polk_Art
    Polk_Art Posts: 1
    edited June 2009
    Stew, I just bought a pair of SDA-2Bs and I been reading a number of posts regarding upgrading the tweeters & crossovers. I read a post of yours from a few years ago stating you were going to use a combination of Solen & Sonicap capacitors in the crossovers. Could you tell me how that worked out for you? Going will all Sonicaps is a costly proposition and will nearly double the cost of the upgrade and cost as much as I paid for the speakers. Did you also replace the resistors? Thx in advance.
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited June 2009
    I know I'm not Stew!!
    Use Sonic Caps in the high pass and Solens/Aeons/Daytons for the low pass. The high pass is critical and the low pass is not as critical. Buy Mills resistors, they are around $3.00 each so no worries there. Existing chassis wire is satisfactory.
    Oh yeah Welcome to Club Polk
  • NJPOLKER
    edited June 2009
    I always forget something.
    Do a forum search because you should find a lot of great info and pictures on the re-build. You may want to consider the TL upgrade as well.
  • fbm211
    fbm211 Posts: 1,488
    edited June 2009
    You might be better off going with 1% daytons available at parts express.I went with those and mundorf resistors.I didnt think I was qualified yet to do the soldering so I sent them to ben to recap.He did a great job and my 2Bs sound much better.Total cost was less than 100.00.I added some deoxit gold to the order to get the free shipping at PE.The mundorf resistors were about 7.00 from madisound.Here is a link...And you should replace the resistors too.>>http://www.madisound.com/catalog/product_info.php?manufacturers_id=142&products_id=8414
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • fbm211
    fbm211 Posts: 1,488
    edited June 2009
    fbm211 wrote: »
    You might be better off going with 1% daytons available at parts express.I went with those and mundorf resistors.I didnt think I was qualified yet to do the soldering so I sent them to ben to recap.He did a great job and my 2Bs sound much better.Total cost was less than 100.00.I added some deoxit gold to the order to get the free shipping at PE.The mundorf resistors were about 7.00 total for both (and shipping) from madisound.Here is a link...And you should replace the resistors too.>>http://www.madisound.com/catalog/product_info.php?manufacturers_id=142&products_id=8414
    Daytons on the low and sonicaps on the high pass.
