Buying NEW Polk Speakers
I preordered the Onkyo TX-SR706 and should be coming in soon and im looking around for some new speakers.I want a nice upgrade from my old RM6700 with PSW350.So far i like the CS1 Center,Monitor 40 fronts,Monitor 30 surrounds.Having a hard time deciding which Sub to get.Any suggestions?thxs
LG C1 77 inch, AC Infinity T10, Denon AVR-3600H, Panamax MR4300, Panasonics DP-UB820, Nvidia Shield TV Pro, PS5, Xbox Series X, Polk Audio Signature S55, Polk Audio Signature s15, Polk Audio Signature s30, SVS PB1000 PRO x2
Budget Setup - https://images.static-bluray.com/htgallery/182210_full.jpg
Post edited by vid33nyc1 on
Congratulations! Try surfing the subwoofer area in this forum for tons of opinions. My personal opinion is that if you are listening to music most, then get a Velodyne or Martin Logan (although neither are terribly cheap). If you are into home theater, then go to http://www.svsound.com and get an SVS sub. Better yet, get two subs and enjoy true bliss.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Thanks for the link and responding.WOW those are nice subs.So now im thinking maybe a combo of
CS1 center
Monitor 40 fronts
SVS PB10-NSD
OR
CS2 center
monitor 40 fronts
monitor 40 surrounds
SVS PB10-NSD
Im on a tight budget so looking for good performance at affordable price.
Budget Setup - https://images.static-bluray.com/htgallery/182210_full.jpg -
I would probably go with the CS-2 if you are watching a lot of movies.My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
Yeah i do watch alot of movies.Sounds good though.thanks for the help.When i decide to go 7.1 later on i hope the speakers wont be to much for the Onkyo TX-SR706
Woah that's crazy... I am planning on getting some Polk Speakers around Christmas, i also am getting some Monitor 40's(Bi-amped) as mains, CS1 center, and Monitor 30's as surrounds. And I am using an Onkyo 606(Not quite the same but close lol) If you have a smaller room, I would recommend the HSU STF-1. That's what I plan on getting later on down the road. And the 706 should be able to easily power anything you throw at it. Polks are generally pretty efficient.
Vid, since your into HT more my recommendation would be to go 2.1 with your setup for now. You have a great receiver to start since its HDMI 1.3a with preouts. You said you will eventually goto 7.1 later on. So for the time being spend all of the money on a pair of fronts + a sub.
A pair of RTiA7's + the SVS sub would be a GREAT start! Thats the bulk of your cost anyhow. That way, the next time your ready to upgrade, you just add your center. Then a pair of surrounds and your set! In the long run this would be, in my opinion, the way to go! Hell, the pair of RTiA7's might just beat out the entire monitor + cs2 setup to begin with for close to the same cost!TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3 -
canderton01 wrote: »Woah that's crazy... I am planning on getting some Polk Speakers around Christmas, i also am getting some Monitor 40's(Bi-amped) as mains, CS1 center, and Monitor 30's as surrounds. And I am using an Onkyo 606(Not quite the same but close lol) If you have a smaller room, I would recommend the HSU STF-1. That's what I plan on getting later on down the road. And the 706 should be able to easily power anything you throw at it. Polks are generally pretty efficient.
I guess we have the same idea:D Pretty crazy.Yeah i have an average size livingroom.My couch is right on the wall 8 feet away from the Tube(sony KDXBR970)Yeah im still rolling with a CRT.Its still a great set.Thanks for the input
Well right now i still have my 4 year old RM6700s.I want to hear what they sound like with the 706.But yeah i plan on getting my speakers piece by piece.Those RTiA7 are nice,thanks for the advice i will have to check those out also.
Hehe no problem;) My this is my bedroom setup and my room is 10x12(yeah it's small) so it's too small for a 7.1 setup so I'm just going to Bi-amp the Monitor 40's. And don't worry about your tv. Sony made some great CRTs back in the day. We've still got an old 32'' Trinitron in our bonus room. I have a 32'' Vizio LCD(VX32L) in my bedroom and it's a great tv. It's 720P/1080i and I got it for $650 from CC. Great tv for the money.
Good luck with your setup -
I may need a lesson in Bi-amping though.Dont know much about it.It seems like everyone is doing it.Should have some Faqs on AVS somewhere for this.
If your using a 7.1 receiver(i'm guessing you are seeing as how you said you were getting the 706) it's really easy to bi-amp speakers. You can just use the outputs for the rear surrounds for bi-amping the main speakers. You just have to go to the speaker setup menu on the receiver and set it from "normal" to "bi-amp" That's what I'm going to be doing with my Onkyo 606. -
If you get a good amp, you won't have any need to bi-amp with your receiver.TV: LG 55LW5600
Pre: Marantz SR6001
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Thats good to know.
My biggest piece of advice is to not dive in head first into this hobby unless you have a spare $5k on hand. You will get a taste of a good sounding system and want to immediately upgrade. It will cost you more money that way. Your best route is to spend a good piece of change up front on your front/main speakers and upgrade the rest of your system from there. The quick fix is always the worst fix. In this case it would be to get your full 5.1 or 7.1 and having 5 or 7 mediocre speakers in your setup.
Now if this were to be a 1 time only endeavor, then by all means getting a quick fix would suffice. What exactly is your budget for now?TV: LG 55LW5600
Pre: Marantz SR6001
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
I would say right now my budget would be around $2,000-$2,500.I have been checking out the Monitor 60 and 70 floor standing speakers.Thinking of going with one those for my fronts instead.All these speakers are not as expensive as they used to be.Prices have dropped.
I just got my new Onkyo TX RS 606 and i went with the TSi 200 for the front. I plain on bi amping them as the 606 is a 7.1 and my room is to small for that so i'll only be going 5.1. For the center i got a CSi 3. The speakers are due to come in this tuesday. I ordered them from JR.com all for $414. I plain on eventually using the TSis as surrounds once i have a larger room and upgrading to a a pair of floorstanding speakers for the front. Good luck with your set up.
LOL im sure it is.Cant wait to start.Thanks guys
Wasup guys.I have my Onkyo TX-SR706,love it so far.I just picked up the CS2 center,Monitor 60 fronts and a pair of monitor 40s.Im still using my RM6700 and PSW350 right now.I still have to pickup the SVS PB10-NSD.Can any of you guys recommend speaker stands for the monitor 40s,at least 36in high?Im having a hard time finding a pair.Thanks
Thanks for the link.I found the Studiotech SP-36 so far.
http://www.studiotech.com/products/speaker_stands/sp_series/index.html
I will search a bit on the site.
I found 2 Pair of stands i like for the Monitor 40s.Cant make up my mind.Hmm decisions.
http://www.standsandmounts.com/index.asp?PageAction=VIEWPROD&ProdID=645
http://www.standsandmounts.com/index.asp?PageAction=VIEWPROD&ProdID=2864
IMO, I think an SVS sub is too much for that setup. I'm not saying your speakers are lacking, but you're taking entry level speakers and pairing them with a monster sub, which if you have to dial down to blend with your speakers means you aren't going to get the full benefit of the sub so why buy it? (unless the plan is to upgrade front stage down the line......)comment comment comment comment. bitchy.
Thanks for the reply brettw22.I sent an email to SVS and this is what they had to say.Here is the conversation.
Hi,i hear alot of GREAT things about the PB10-NSD subwoofer.I plan on buying it VERY SOON (wont be discontinued anytime soon i hope) and i would like to know if it would be a good fit for my speakers.I just purchased the Polk Audio Monitor 60 floor standing speakers,Monitor 40 surrounds and CS2 center speaker.I currently have the Onkyo TX-SR706 receiver.I am upgrading from my old polk RM6700 sats and PSW350 sub.Thank you
Thanks for contacting SVS, and for considering the PB10-NSD for your system. Nope, we wont be discontinuing the PB10 any time soon, it's the best-performing sub anywhere near its price until you get up to the PB12-NSD, that is.
The PB10-NSD will work perfectly well with those speakers, and be a rather noticeable step up from the PSM350, for sure. It's got a very flat and extended top end, and so will have no problem with an 80-100hz crossover.
What size room is your system in, and how loud do you like to listen?Thanks again for your note. We appreciate the opportunity to earn your business, and look forward to hearing from you further.
Wont be discontinued anytime soon,thats great to hear.Thanks for responding.I live in an apartment so I would say my livingroom is around the area of 16ft x 10ft,if that makes sense.I sit about 7 feet from the TV.I like to play my system pretty loud.I have the Onkyo set to absolute with volume usually in the high 50s,sometimes low 60s.
The PB10-NSD will certainly be able to get to get pretty loud (~107dB peaks) in that room, and stay deep and clean while doing it. If you haven't experienced clean, SVS-style deep bass at high levels, you're in for a treat!
Sit the PB10 in a front corner, let the Audyssey MultEQ XT auto-calibration in your TX-SR706 work its magic, sit back, and enjoy
He doesnt seem to think so.you think 300 watt sub to much for the setup?
Dude.... Get the SVS. You'll be glad you did. If you watch a lot of movies you'll love it.
I also don't see why the sub wouldn't be on par with the speakers? Isn't that there bottom of line sub? Its not like hes getting the Ultra13 or something.
I had four Rti4's and a Csi3 paired with a SVS 20 - 31 PC Plus sub. And it was amazing!
I say go for it.
Cheers
Nick -
Why would he have to dial down the subwoofer to blend? I wouldn't call the PB10 a monster subwoofer since it's the entry level SVS.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Thats why i wanted the PB10-NSD because its their entry level sub,highly rated and i figured it would be a good fit.I will go for it.Thanks for your opinions guys.
Go ahead and get the SVS, just don't expect your neighbors below you to like it as much as you do.......;)HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
A sub can have the most dramatic effect on an HT rig. Competent speakers with a great sub will sound much better than with an entry level sub. The SVS will keep you happy through a series of speaker upgrades...go for it.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Just a pointer on the SVS PB-10 and PB-12 - they do not have speaker level inputs - only RCA/Line Level.
I run my speakers and sub the "polk" way cuz I like to listen to music using yamaha's "pure direct" mode and preferred not to have my sub as just a 'brick' when going old school 2-channel mode. Because of that I use the speaker level config.
Ah well...so much for considering the SVS PB-10.
