Rotel and adcom amps & going price per model #'s
faster100
Let me know what model #'s go with what prices on these 2 brands, doesnt matter how many channels or price, i just want a run down on models you have used or seen and what a good price would be per amp.
adcom= model numbers of good units= going rate$$$
Rotel= model numbers= going rates$$$
No other brands, and for the most part no current models so i can find them used. Thanks
and NO 2K$$$$ models Please,,,,,,,,,,,,,
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
I read this review today, interesting mention of useing this amp with a good receiver,
pasted:
Rotel has done it again with the superlative RMB-1075. I think this product represents one of the best values in home theater amplification on the market right now, and recommend that you put it on your short list when shopping for upgrades. It would be a fabulous addition to the pre-outs of any surround sound receiver, bypassing the often less-than-adequate power amplifiers they have, and especially when you migrate your system to DVD-A and SACD. But, also, it would be wonderful to pair it with any dedicated processor out there. I have been working on this review for quite a while, but I have had so much fun showing it to friends, and enjoying it here in the lab, I put off publication because I did not want to send it back.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
bump.....////MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
faster100, i'm at the same point myself. I am looking for a two channel amp. i've been looking at Rotel, Adcom, Carver, and Onkyo. nothing over like $500 used for a 2 channel. Looking at around 100 to 150wpc range.
so i'm very interested in what prices should be paid for these amps.PolkFest 2012, who's going>?
If they are current models you can expect to pay at least 50% - 70% of retail if they are used.
For older models you can expect to pay about 25% - 50% of retail. The high end of each of those spectrums is a bit high.
I've seen Rotel RB-990BX amps go for $200 on ebay, and I've seen them go for $450. It just depends.
There are some decent deals on Rotel stuff on ebay right now. I think I saw several RB970 amps going for $200 or so, and a couple of RB990 amps for around $400 (retail was $999, so 40% is 'ok' but I wouldn't say it's a deal).
If you have local hi-fi shops check them regularly for used/consignment gear. I've seen some killer deals at the ones here in Austin. Check ebay and audiogon every day or two, and eventually you'll find a killer deal on something that you want. Good luck. -
Thanks phuz ,
Danger boy, maybe we can get some model #'s and thoughts later on from people who have used said amps or what they think. when people get home from work and on here laterMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
faster100, how do you plan on using these amps?
sounds like a good idea.. some of the amps i've been checking out on Ebay are
Adcom GFA-555
Adcom GFA-5400
Adcom GFA-5503
Carver A-400X
Rotel RB 980 BX
or 3 more Marantz MA500's to add to the two I already have.
anyone have any experience with any of the above amps? I'm sure there are several more good amps out there that I have not found yet. What I want the two or three channel amp for is to bi-wire my front 800i's.PolkFest 2012, who's going>?
far as adcom, I really like the 7500 5 channel amp for the power and the money, the 5500 series seems alittle high priced now, or the lower powered 7300 multi channel amp by adcom looks ok but only 60 wpc x6 i thinkMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
