About to ship LSi9 Speakers... need help!
Shicks18
Shicks18 Posts: 397
edited August 2008 in Speakers
I am about to ship my LSi9s to my apartment back up in Columbia. The box was only opened to make sure the speakers were in good shape and placed back in and taped back up. The original box and packaging are still in 10/10 condition. For a 2 day transit that is insured via Fedex, will my speakers be ok? I can't find another box that is bigger to double box!
TV: LG 55LW5600
Pre: Marantz SR6001
Front Amp: Parasound HCA-1000A
Center Amp: Marantz MA500
Mains: Polk LSi9
Center: Polk LSiC
Sub: HSU VTF-3 MK-2
Games: Xbox360 and PS3
Post edited by Shicks18 on
  • BottomFeeder
    BottomFeeder Posts: 1,684
    edited August 2008
    There's no guarantee, but they SHOULD be ok.
    Original boxes were made to handle some minor to medium bumps, so most times they'll arrive just fine.
    Good luck
    "Wish I didn't know now what I didn't know then." Bob Seger
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2008
    Usually when I go to Kinko's and use Fedex, they have a large assortment of boxes that can be purchased along with packing material. Personally, I'd double box along with bubble wrapping the existing stock ones. This also keeps the thieves from exactly knowing visually what's in the box too.
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    Yea, looks like they will fit in a 24x24x24 box
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2008
    You should be okay. Use the original packaging and stuff additional paper / foam in any crevices to make sure the speakers are packed tight.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    I found a double box that is big enough for the polks. Now my next and final question -- what is a good way to ship a subwoofer without the original boxes? It is a HSU STF-2. It weighs 44lbs. What kind of packing material should protect the woofer? Are double boxes a must?
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • AndyGwis
    edited August 2008
    How far is it being shipped? Can you contact the manufacturer to get a replacement box? I'd be more than afraid to ship something large, heavy, and somewhat fragile in anything other than the manufacturer packaging.
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    Its Texas to Missouri. Usually takes 2 days on fedex ground. I won't have enough time to get a replacement box. I do plan on double boxing. Also using bubble wrap all around the actual sub and peanuts to fill up the space. Will that work?
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • AndyGwis
    edited August 2008
    I would definitely go with harder foam than peanuts. Peanuts don't offer much support, they just kind of fill space.
    I'm not sure when you can get the foam. I've broken up a few styrofoam coolers and used them, but that's messy and not optimal. I'd try to find some 2-3" thick foam pieces to put between the bubble wrapped sub and box(es).
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    sounds good. thanks for your help
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • suprafantx
    suprafantx Posts: 249
    edited August 2008
    Add few dollars for insurance also.
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
    F1nut Posts: 51,788
    edited August 2008
    DO NOT use peanuts or bubble wrap. You want to place the item in a heavy plastic bag or the like. Buy the styrofoam type insulation, it comes in sheets, from Home Depot or Lowes. Cut pieces to fit the carton, lining the bottom, sides and top. Make sure the item is packed tight. Then, place that box inside of another and fill any space with more of the sheet material. Make sure the cartons (boxes) are at least double wall construction. All this takes extra time, material and money, but it's the only way to do it. Two days or two weeks of shipping time does not matter, your package will get the crap beat out of it in the first hour, plan on it!
    Also, it's a good idea is to take pictures as you pack. That way, in case there is a damage claim, you have evidence as to how well it was packed.
    Don't forget to insure it, but unless it's packed to withstand a bomb blast, it won't help you.
  • meirco11
    meirco11 Posts: 47
    edited August 2008
    i just wanted to say that my new lsi9s are great with my rotel ra1070.
    how long its take for the lsi9 to break-in???? they sound a bit "close" now.
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    some say 70, some say 150.. it depends on who you ask I guess
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • fossy
    fossy Posts: 1,378
    edited August 2008
    insurance for sure--- why would ya wanna leave texas in the first place ????:D
  • Shicks18
    Shicks18 Posts: 397
    edited August 2008
    I don't =P .... but I gotta graduate from Univ. of Missouri before I can come back! 1 more year til my MBA !!
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2008
    For something that I don't have the original box for I like to put the item in a plastic bag, then wrap it in a few layers of big bubble wrap. Then place it in a relatively close-fitting box with all sides having 1"+ styrofoam (styrofoam doesn't have to extend the entire length) and fill the empty space with peanuts. Then double-box it and put either styrofoam or some other foam-like padding on each side (again, doesn't have to extend the entire length of each side just needs to keep the inner box stationary which peanuts won't do). Fill the empty space with peanuts and call it a day. Hasn't failed me yet.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2008
    I recently had a sub shipped to me and it was single boxed with peanuts. I'm now waiting on ups to finish the claim as the feet were shoved into the box completely broken and rendered the sub useless and the box resonated and had air leaks at every seem.
    It also had several damaged areas all over it from shipping it like this.
    I also had some polk speakers the rti a5's shipped in orginal box and double boxxed and no damage was done.
    Had some surrounds the rti6 shipped in orginal box only and they speakers were ok but by miracle only. The box had a hole the size of a softball in it but the speakers made it out ok.
    Had some smaller stuff shipped in orginal box only and it was ok but again the box was beat up.
    If it were me i'd at least double box to help insure the wellbeing of your gear after seeing first hand how badly shippers handle these boxs.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
