RM6800 y cable or not
faheydesign
Hi,
I just got a set of RM6800 and have decided to connect them through the LFE connection. I was wondering if anyone had any luck connecting with y cable or is it better just to go through one channel?
Also the instruction illustrate hooking up the left and right speakers through the sub. I've looked for an argument for this and have been unsuccessful. Any one know why?
thanks
thanks
Post edited by faheydesign on
First welcome to Club Polk. Second using a y adapter is just fine. Stick around this is a great place to learn.
Ben -
even i have same system, i just connected single sub cable to the left channel on Sub
works fine for me. -
Using a Y adapter can increase your sub volume a few db higher which is also the same as increasing the gain. In short, you may or may not use a Y. It is only a matter of personal preference.
It rely is a debatable subject weather it helps or not but from what I have seen heard and read. It does not help what so ever. But if you feel better knowing that both input are connected by all means use a y adapter.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
