MM2124 Vs. MM2124DVC
AudioSystems09
I am currently trying to decide what subwoofer to purchase, and I definitely like the reviews and specs on the Polk/MOMO Series MM2124 12" subwoofers. However, I am not sure which one to get, the single voice coil, or the dual voice coil version.
What are the advantages of single versus dual voice coils?
Which one will last longer?
What would be the difference in the amplifier I would have to get?
Which one "hits harder," if there's a difference?
The music genres I listen to are mainly Techno/trance, and some rock/metal.
Thanks!
Thanks!
No difference. Its simply to offer different loads for different amps. For instance, if youre going to use a 2 channel amp bridged mono then you need a 4 ohm SVC sub. If youre going to run a mono amp at 2 ohms mono then youll need the DVC so you can wire each voice coil in parallel and have a 2 ohm load.polkaudio sound quality competitor since 2005
