psw10 subwoofer opinion....
hdoggie24
I was wondering if anyone had opinions on this. I currently have a polk rm20 set hooked up to a sony sa-wm40 sub all sent to onkyo 606. I love the sound since i mainly use it for movies. But was wondering if I should upgrade the sub now. This sub is a little bit older and I have added stuffing to it already to make it sound better. Would the polk sub be better than my current sony one. Or should i stay with the sony for a now and upgrade to an even better one when I can afford it. Who knows when that will be though? Thanks
Post edited by hdoggie24 on
I would say the psw 10 will suffice but if you can afford it go to something like the psw100 that way you are giving yourself a little headway in the event that you want to upgrade your speakers. I have been running my psw10 now for about a year. Works and sounds great for my bedroom.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I just set up this surround rm20 and I won't be upgrading anytime soon or possibly for at least 5 years or so. I got these so I cound mount them on the wall. 2 small kids running around so everything has to stay off the ground. So should I still buy a better sub than psw10? Is the psw10 comparable to my sony sa-wm40 or is it a significant upgrade worth getting.
It would be worth the upgrade the psw10 will do the job just fine. I was just thinking if you were going to be upgrading but if you are not for 5 years or so i would say go with the 10 it will be an improvementHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Hello- also do not count out buying used -- more bang for the buck -- I was just watching a psw505 on e-bay to see what it sold for -- it sold for less than half what it cost new--
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=200243777594 -
I started reading more about the psw505 sub and it sounds pretty awesome. How much better would this be than my sony sa-wm40 sub. I just want opinions if I were able to come up with the money for it....
That would be to much power unless you are going to be running some bigger speakers to go with it. It is a great sub don't get me wrong but for what you will be using it with "the rm20's" it would be overkill *10HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
So what recommendations does everybody think that would be significantly better than my sa-wm40 sub. I thought about getting another sony sub because i could find it for cheap. Or is there a better sub out there that would be better?
hdoggie--- to answer your question , yes there are a ton of better subs than the sony that you are using.But like bigaudio was sayin, get one that fits into your system.
The 505 I posted about was just an example of what can be had going the used rout.psw10's can be had for around $100 or a little more off of flea bay.
http://cgi.ebay.com/New-Polk-Audio-PSW10-Black-10-Sub-woofer-Subwoofer_W0QQitemZ330258368724QQihZ014QQcategoryZ3275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem[PHP][/PHP] -
Where are you located bud?
I've got an extra S8 now that i've been thinking of unloading.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
bigaudiofanatic wrote: »That would be to much power unless you are going to be running some bigger speakers to go with it. It is a great sub don't get me wrong but for what you will be using it with "the rm20's" it would be overkill *10
Is there really such a thing as overkill with a sub?____________________
Pool: Atrium 60's/45's -
Is there really such a thing as overkill with a sub?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I used to have PSW10 and bookshelf monitor speakers powered by 702 and I personally do not like PSW10. It doesn't have enough bass for me and doesn't have quality bass. It was a big difference with that system when I upgraded the sub to PSW505. I think
PSW303, 404, and 505 series are better choices.Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1. -
My room is 25foot long 12 foot wide and 14 tall and the sub fills my room. In my opinion the advice on this from me and fossy was good. You don't need something that is going to mute out your mids and highs you want something balanced the psw10 is a great sub guaranteed better than the sony. And here is an idea buy it from crutchfield. If you don't like it within 30 days you can return it with them paying the shipping and get a full refund.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
From just looking at the specs I'd tend to agree.
However, there is a customer review for the PSW10 where one owner says he used to have a PSW303 and he thought the PSW10 was better.
Things that make you go hmmmm......
Your room is 25 foot long, you need better sub than PSW10.Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
LOL bud NO I DONT you see i dont need to vibrate my eardrums. I like a balanced sound and when I watch movies I get the boom i need.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Erik Tracy wrote: »From just looking at the specs I'd tend to agree.
There is no way that PSW10 better than 303, 404, or 505 series subs unless that person does not like deep bass. PSW303, 404, or 505 series are long throw drivers while PSW10 is not, also out put power of PSW10 is less than a half of the out put power of PSW303, 404, or 505 series subs.Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
Were ya located bud come have a listen it will hurt your ears if I want it too. Bridgeton NJ for me I like deep bass. I have been learning for over a year here and know that this sounds good. Things like rap will hit in my room. Besides he never said that the psw10 was better than the 303 or any of the others you are probably just looking at specs we actually listen to these. AND yes people will choose a smaller sub sometime rather than a bigger one Erick did that research and I agree with it.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »Were ya located bud come have a listen it will hurt your ears if I want it too. Bridgeton NJ for me I like deep bass. I have been learning for over a year here and know that this sounds good. Things like rap will hit in my room. Besides he never said that the psw10 was better than the 303 or any of the others you are probably just looking at specs we actually listen to these. AND yes people will choose a smaller sub sometime rather than a bigger one Erick did that research and I agree with it.
Just my personal experience, PSW1000 is much better than PSW505, PSW505 is much much much better than PSW10. Actually, I had PSW10 for free from Fry's when I bought other Polks speakers.Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
But you might have a bigger room than him or me but mine fills the room with rock solid bass PERIODHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
You got it right. PSW10 will hurt your ears because of distortion and higher frequency sound (35 hz or higher). That happened to me that is why I upgraded my PSW10 to PSW505 then PSW1000. You will enjoy more pleasing bass (as low as 20hz) with quality subs which has more power out put so you listen at low volume and less or distortion.Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
so would a psw505 be too powerful for my rm20 surround set..... could always turn it down if too much right? thought about dual subs but would rather have just one, don't want too much crap in the living room. kinda of wanting to ditch my sony sub. i think i'm missing something.
No there isn't. It's always good to have headroom. When you're at the limit and push things, that's when things break.so would a psw505 be too powerful for my rm20 surround set..... could always turn it down if too much right? thought about dual subs but would rather have just one, don't want too much crap in the living room. kinda of wanting to ditch my sony sub. i think i'm missing something."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Agree with Face.
Yes, you could always turn it down if it is too much. I suggest that just get one good sub. I ran 4 subs before and had a hard time to have all 4 in-phase. Also when you have many subs produce the low frequency sound, you will tend to listen to the only low frequency sound from your best sub.Living room
Player: Oppo 95.
Man Cave
Player: OPPO 105.
Sub: Rythmik F12.
