what about the new mobile monitor?
Kinetic
Kinetic Posts: 437
edited September 2008 in Car Audio & Electronics
does anyone have heard the new mobile monitor?
my roomate wants to buy a component system for his civic so i obvioulsly recomend him polk audio, and i show him the new mobile monitor.
the problem is that the MM are 6 3/4, so maybe a MOMO should be better since are 6 1/2, but is it a big difference in SQ?
also what do you think of this amps for the component system?
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=6250
or
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5720
the alpine can be bridged in to a 150 x 2 at 4 ohms and have a nice crossover
Z
/////Alpine CDA-9887 HU
/////Alpine KTX-1000EQ
/////Alpine PDX-4.150
/////Alpine PDX-1.1000
Polk Audio SR 6500
Polk Audio SR 124 DVC
KnuKonceptz MKS Kable
G35
/////Alpine SPX 17PRO
/////Alpine SWX 1243D
Post edited by Kinetic on
  • exalted512
    exalted512 Posts: 10,734
    edited August 2008
    They are a fantastic set of speakers. What year is his Civic?
    -Cody
  • Kinetic
    Kinetic Posts: 437
    edited August 2008
    exalted512 wrote: »
    -Cody
    2003 coupe
    just like this one
    Z
    Polk Audio SR 6500
    G35
  • exalted512
    edited August 2008
    either speaker, your more than likely going to have cut metal
    -Cody
  • Mike B.
    Mike B. Posts: 54
    edited August 2008
    MOMO & MM have ~ same cut out/ mounting hole 5" for the 6 1/2-6 3/4
    They have added "line drawings" to most of the 12 volt product info on the site...
    Mike Bobelak
    Heartland Regional Manager
    Polk Audio
  • cam5860
    cam5860 Posts: 632
    I was just looking at the specs on the mobile monitor subwoofers. It states that they have 1 inch of xmax or 25 mm of xmax. If thats correct these baby's should get loud as hell. The sr series subs have 0.64 xmax or 16.25 mm of xmax.
  • Jstas
    Jstas Posts: 14,993
    Ugh.
    xmax is not the only deciding factor on output levels.
    Expert Moron Extraordinaire
  • pentavolvo
    pentavolvo Posts: 68
    with the 5" diameter u only have to cut plastic on the civic if i recall and the metal door panel itself is fine but i could be wrong
  • Kinetic
    Kinetic Posts: 437
    thanks, im still waiting for those babys to come here.
    Z
    Polk Audio SR 6500
    G35
  • cam5860
    cam5860 Posts: 632
    The large diameter coil contributes to the high bass output and high power handling of the driver (700 Watts Continuous, 1400 Watts
    Peak). In order to allow long linear movement of the cone, the winding width of the coil is 40mm and double ceramic magnets 1-3/8
    inches (36mm) thick are used. The SR 10" and the SR 12" woofers boast a mechanical excursion limit of over 65mm (around 2-1/2") and
    an Xmax of 16.25mm, over 1mm longer than one of our closest competitors and over 2.3mm longer than another similarly priced competitor.
    Xmax is a measure of the one-way limit of linear travel of a cone. A woofer with an Xmax rating of 13mm means that the cone
    can travel a total of 26mm from furthest back position to furthest forward without undue distortion. It is a crude indicator of the undistorted
    excursion limits of a driver. Why is that important? How loudly a driver plays is a function of the diameter of the moving element
    (cone) and the excursion (how far the cone travels back and forth). A smaller diameter cone can play as loud as a larger diameter
    cone if it can move a longer distance. Stated another way, a 10-inch woofer with a 16mm one-way linear excursion would have a peak
    output of 112dB while a 12 inch woofer with a 10mm one-way linear excursion would output 111dB.
  • ROOGER82
    ROOGER82 Posts: 30
    cam5860 wrote: »
    the large diameter coil contributes to the high bass output and high power handling of the driver (700 watts continuous, 1400 watts
    peak). In order to allow long linear movement of the cone, the winding width of the coil is 40mm and double ceramic magnets 1-3/8
    inches (36mm) thick are used. The sr 10" and the sr 12" woofers boast a mechanical excursion limit of over 65mm (around 2-1/2") and
    an xmax of 16.25mm, over 1mm longer than one of our closest competitors and over 2.3mm longer than another similarly priced competitor.
    Xmax is a measure of the one-way limit of linear travel of a cone. A woofer with an xmax rating of 13mm means that the cone
    output of 112db while a 12 inch woofer with a 10mm one-way linear excursion would output 111db.
    brain overload!!!...on another note...I want the Mobile Monitor 6x9's. Anyone willing to trade them for a brand new pair of Momo 6500 components?
    (Insert clever sig here);)
