????....PC Digital out splitter
dee1949
dee1949 Posts: 1,425
edited August 2008 in 2 Channel Audio
..can you split the digital output of a sound card to direct to 2 sources without losing quality. I would like to send audio to HT system or my two channel setup.
Would a Y splitter work? One cable to DAC and then 2 channel. Other to HT.
Is there such a thing as a digital Y splitter?
Post edited by dee1949 on
  • jakelm
    jakelm Posts: 4,081
    edited August 2008
    I dont see why a coax/RCA splitter wouldnt work.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Face
    Face Posts: 14,340
    edited August 2008
    What kind of sound card do you have?
    You can buy a adapter for Xfi cards that has one digital coax out and one optical out. I used one of these devices and it worked fine. I would not use a Y.
  • dee1949
    edited August 2008
    ...CHAINTECH AV-710 7.1 ....suppose to have good dacs on back channels that can be used for 2 channel....its cheap....but so am i....retired and POOR. My 2 channel system has the Polk sda-crs's with Carver M1.0t amp and MSB Link III. The HT uses a Denon receiver w/old collection of speakers of which the front channels are Mission/Cyrus 781's. The Chaintech only has 1 optical out. Would need optical splitter. Any loss of signal by splitting?
  • Face
    Face Posts: 14,340
    edited August 2008
    If you use the digital out, you're bypassing the DAC's.
    If you want to use your card's DACs, you would need to use the analog outs.
  • dee1949
    edited August 2008
    ...not too concerned with HT....but would be nice....Could I send regular 2 channel by RCA to HT and also send optical...simultaneously. I need a 35' run of optical cable to get to DAC....2 channel system is in another room.
    Thank you for responses.
  • Face
    Face Posts: 14,340
    edited August 2008
    It depends on the card, check the manufacturer's website. I know I can't with my XFi.
