I am about to buy LSI15's
Frank840
Frank840 Posts: 262
edited January 2009 in Speakers
I dont have a amp I know i need one. but I talk my finacee into getting LSI15s :D.So now my reciever i cant select a 4ohm i can only do 6 and 8. the question is if I bi amp the speakers will that be less of a load and if i turn it up a little bit will it cause clipping?
I dont know about all tweeter stores but the one in Belir has LSI15's for 999 a pair new.
http://www.pioneerelectronics.com/PUSA/Products/HomeEntertainment/AV-Receivers/EliteReceivers/VSX-82TXS
Thanks Frank
- This your Bush?
Pioneer Elite Sc-25
Polk Lsic,15's,9's, PSW1000
Post edited by Frank840 on
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited July 2008
    From what I've read on various places on the web, the Pios don't play well with 4-ohm speakers, they like to go into protection mode, and shut down. You might be able to get away with bi-amping, if it's changing it to an 8-ohm load.
    Sounds like a good price for the 15's though, but I'd look for some separate amplification, with the savings.
  • McLoki
    McLoki Posts: 5,231
    edited July 2008
    I would not worry about clipping as much as just driving your amp into protection mode. With low impedance loads, it may demand more current than your AVR can supply driving it into protection even at lower volumes or when crossed over to a sub.
    You can try it, but be prepared to get an amp.
  • stereojunkie
    stereojunkie Posts: 10
    edited August 2008
    great price on the 15's, I wonder if they are clearing them out at your tweeter store. Take a listen to the Cambridge Audio gear at Tweeter and see how they mate with the 15's.
  • meirco11
    meirco11 Posts: 47
    edited January 2009
    now,after some months i can tell to all my friends her that my rti a7 are realy great speakers.yes,i know, i was confused at the first weeks and i am sorry about it.my rti a7 sounded very good with my hk3480.(120wpc).
    my lsi9 hook to rotel amp(ra1070/100wpc)and it is realy great match.
    my rti6 hook to nad c372 and the sound is good. iam a stereo fan and i think that the rti7s are realy great speakers. but on top of all i know that my lsi9s are realy the best of the best.
    all my polk speakers(rtia7,rti6,lsi9)are cherry finish.
    thank you all and goodluck!
  • Pepi28
    Pepi28 Posts: 248
    edited January 2009
    Where did you come from?^ Hijacking someone's thread.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
    Hi Frank. I just recently purchased a pair of LSi15s and am very happy with them. My yamaha amp can be switched from 4 to 8 ohm but I have it set to 8 ohm now and the speakers and amp are fine. Biamping will not change the output impedance of your receiver. Running speakers in parallel or in series will however change their input impedance....but who wants to do this. As a general rule it is always better to try to match imput impedance with output impedance. I am getting a new amp this next week and from what i have been gathering these speakers are good with a receiver but shine with a high power amp. I wil be seeing for myself next week. I say get the speakers now and you can always add an amp later....lots of good amps for $200-$300 here.
  • brittle
    brittle Posts: 37
    edited January 2009
    I have a Pioneer VSX94TXH and bi-amp my front LSi15's, they sound fantastic with never a hint of clipping.
    Brittle
    Pioneer VSX 94TXH AVR
    Polk LSi-15 front
    Polk LSi-15 rear
    Polk PSW1000 sub
    Polk LSiC center
    Samsung HL67A750 DLP
    Sony PS3
