Muddy presentation
Jeff Beaird
Jeff Beaird Posts: 217
edited August 2008 in Vintage Speakers
I had left the world of Polk but now I am back..! I purchased a pair of LS90's and a CS 350Ls center w/4 Monitor series 2 for surrounds... Boy does the center sound muddy..? even the wife noticed!!!
I am wondering if this center is power hungry? I don't have a Mega buck system but the Denon should feed it 80W(rated power)...??
Any ideas..? Is it time to re-cap? I love the LS90's and I thought they timbre matched... so..???
Thanks, Jeff...
Post edited by Jeff Beaird on
  • tugboat
    tugboat Posts: 393
    edited July 2008
    I had a CS350 running off a 100w Pioneer and teamed up with RT800s it sounded well matched. When I tried it with 1.2TLs, it was as you described. I had to go out and get the CSI5.
    You might want to check to make sure the tweeter is working. If it goes out, it will be all mids.
    I'm sure others here will have a better course of action for you. Hang in and they'll be here.
    Driver carries only 20 dollars in ammunition
    Pedestrians have the right of way, unless they are in the way
  • soiset
    soiset Posts: 724
    edited August 2008
    I've proposed a solution here:
    http://www.polkaudio.com/forums/showthread.php?p=898616#post898616
    Should cost about $90 total for a used active crossover (Rane AC-22) and whatever you can get a low-powered amp for, to power the tweeter. I'd imagine that would make a dramatic improvement.
