For those looking for a new media server
Face
This may be worth looking into.
http://www.dell.com/content/products/productdetails.aspx/desktop-studio-hybrid?c=us&cs=19&l=en&s=dhs&ref=homepg
Available with a 320 gig HD and even comes with a optical out in base configuration. Depending on the specs of the sound card and if AISO drivers would worth with it, it may make a nice media server on the cheap. Plus, it would be easy to hide away so you wouldn't hear any fan noise.
Post edited by Face on
Interesting unit, though at that price it would have been nice if they had spent the extra $5 for a 500GB or larger drive.
That does seem to be a compelling option. Is that integrated graphics hardware sufficient for BluRay?
Interesting little box. But you can also get a ps3 and drop in a generic 250GB hard drive for under 100 bucks and it'll cost less.
I think there are other issues too although I like the look and admire the effort. I configured one as Base + 4GB + 320HD + Blueray + Vista Premium and no monitor and price came to $1,050. A little pricey IMO.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I'll stick with what works my apple TV. Of course I may try it out.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I'll stick with my HP z560. The dell basically does the same thing, but the HP has 7.1 analog out, optical, coax, and 2 video outs.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I'm new to the PS3 thing, but.. you can swap out the HD? How do you do that? Can you back up the drive once it is in?HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
a_mattison wrote: »I'm new to the PS3 thing, but.. you can swap out the HD? How do you do that? Can you back up the drive once it is in?
Yes.
I just swapped out my 60G with a 250G. It has to be a 2.5" SATA drive 5400rpm (my understanding is, at higher rpm's, heat becomes an issue)
You'll need a large enough flash drive, or a FAT32 formatted external drive. PS3 has a back-up and restore feature that works very well. It retained all my settings, DLC, and game saves. (even the copy protected ones)
Back up the existing drive, restore to the new. And it doesn't void the warranty. -
LessisNevermore wrote: »Yes.
Sweet. I'll have to try this out. Also, I keep forgetting that you are in the area. We'll make sure to drop you a note next time the Rockford guys are getting together.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
a_mattison wrote: »Sweet. I'll have to try this out. Also, I keep forgetting that you are in the area. We'll make sure to drop you a note next time the Rockford guys are getting together.
Please do!
About all I have to add to the party, is my XPA-5, but it brings a big grin to my chevy chase.
If you have any problems with the HDD swap, let me know. -
You shouldn't have any problems, though. It's one of the easiest computer upgrades I've ever done. The only thing easier might be swapping out a power cord...;)
Pop off the plastic cover plate. Unscrew the one retaining screw. Slide the cage back to unlock it, slide it out. Take the cage off the old drive, put it on the new. And reverse. Basic instructions are even in the ps3 manual.
When you boot it up, it'll ask you to format the drive and you're good to go.
Might as well go 320GB as you can never have enough space. Then again, you could pop on an external 500GB drive via usb too. I've watched movies on my external drive. Works great, as long as it's formatted fat32. Use something like swissknife to format it though as xp only does limited partition sizes.
