2m IEC Power Cable
zingo
I no longer have use for a custom power cable. It started life as a 4m AR Pro Performance II, but I only needed the male half for a mod. So I purchased a heavy-duty male plug, soldered it on, and wrapped it up tight. The cord has been tested both with my multi-meter and my amplifier and it works great. The cable is stiff because of it's 12g leads, but stays where you put it with no problem. The metal clap is just there for extra support and the cable can be used with or without it; your preference. It's not super HIFI, but definitely a good upgrade from a stock power cord.
SOLD
SOLD
Post edited by zingo on
PM sent.TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
mine!TNRabbit
Sunfire TG-IV
