Which amp for my subs???
Subwoofer9
Subwoofer9 Posts: 2
edited January 2003 in Car Audio & Electronics
Ok I need some help with picking an amp that will push my two 12" 400 watt Polk subs. I want some major bass but I can only spend $200. If anyone can help me out it would be very much appreciated!! Thanx,
Adam
Post edited by Subwoofer9 on
  • Systems
    Systems Posts: 14,873
    edited January 2003
    Try WWW.SAVINGLOTS.COM
    They have a JBL BP600.1 Mono class "D" amp. Makes 600 watts rms at 2 ohm for $190
    They have other amps as well. I founf them when I was surfing the net last week.
    Chris
    Testing
    Testing
    Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2003
    if they're 400 rms and they're polk 12's, then they're either DB's or DX's...
    from experience... i suggest a good quality class D... an old mtx 500d would be idea... they came out of the box 700 - 750 rms into 2 ohms.
    a newer mtx 6500d would also do the job well.
    the jbl 600.1 is a good amp that is inexpensive, but it lacks an SS filter, and they are only 500 - 550 at 12.5 volts, doing their marked 600 at 13.8...
    the polk 12's need something a little more... 350 per sub i've found to be ideal on them. -- the mtx would be the way to go... 600 - 650 at 12.5 and upwards of 700 - 725 or more at 13.8
    happy hunting (last check 6500d's were about 250 on ebay new in box and crutchfield has them on sale right now for 299 i think or something)
    The Artist formerly known as PoweredByDodge
  • Subwoofer9
    Subwoofer9 Posts: 2
    edited January 2003
    Hey guys thanks for helping me out. I will check those amps out and try to make a decision on which amp to get! Thanx again,
    Adam
