Logitech Squeezebox Duet Network Music System
BLACKHAMMERJAMM
BLACKHAMMERJAMM Posts: 69
edited August 2008 in Electronics
Anyone tried this Logitech Squeezebox Duet Network Music System? Is it any good?
Sony KDL-52XBR4
Onkyo Pro PR-SC885P
NAD T975
LSIi15's front
LSIiC center
LSIiFX's surround
LSIi15's rear
PSW1000
Sony BDPS2000ES
2nd system
Sony STRDA5300ES
Sony PS3
LSi9's front
Klipsch sub
under construction
Post edited by BLACKHAMMERJAMM on
  • nspindel
    nspindel Posts: 5,343
    edited July 2008
    Yup. Incredible....
  • WilliamM2
    WilliamM2 Posts: 4,811
    edited July 2008
  • nspindel
    edited July 2008
    If you've got your library on disk, running a squeezebox beats the heck out of trying to use a pc as a source. And the Duet gives you the awesome controller. I've got a heavily modded Squeezebox which sounds amazing, and I use the duet controller to run it. I've got the duet player up in my bedroom that i control with an old pda.
  • JoeLR
    JoeLR Posts: 19
    edited July 2008
    I tried one out for a 30 day trial... When it worked, it worked well. BUT, I just had too many issues w/ it--WiFi dropouts all the time. Oh, and there's nothing "wrong" w/ my WiFi network, btw--everything else on my network works perfectly w/out a hiccup. I need a WIRELESS music server, so the dropouts were a deal breaker for me. I actually use an Apple TV of all things; ZERO issues, and sounds terrific. I use my iPod Touch as a remote, so no need to even have the TV on... Then again, I can be accused of being an Apple fanboy...
  • nspindel
    edited July 2008
    Yes, I do agree there. Had some wifi dropouts as well, they weren't pretty, but I've got a wired setup now and it is flawless.
  • Marty913
    Marty913 Posts: 760
    edited July 2008
    I've had one for several months and it's set up wireless. Works great and I have had zero dropouts. My only complaint is the controller can be a little slow.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • szhleppy
    szhleppy Posts: 325
    edited August 2008
    I bought the Duet a couple of months ago from Amazon. Had to exchange the first one and spent about 2 weeks with tech support getting the 2nd one to work. Finally found a network setting on the Cox network that needed to be modified.
    The concept is great. I was using it wireless and just had too many minor issues to be a good solution (slow controller, dropouts, etc...). I wish I could blame my wireless network, but it is solid with my laptop even out into the far end of the backyard.
    I ended up returning it to Amazon. I'd still like to go back to a Squeezebox as my source, but it needs to be a little more solid and faster before I'll try again.
  • BLACKHAMMERJAMM
    edited August 2008
    Thanks for all the input, I have one coming in tomorrow and will let you know how it worked.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BLACKHAMMERJAMM
    edited August 2008
    Wow, this thing rocks... logged on and it was running in no time... Didn't work with WMA, but worked great with WAV, and flac. so far I think it sounds better than my CD's.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • BLACKHAMMERJAMM
    edited August 2008
    nope, I'm wrong... The SB is good but not better than my BDPS2000ES, so I think its off the mod center... I will do a few more tests with the unit and cables before its packed up.
    Sony KDL-52XBR4
    Onkyo Pro PR-SC885P
    NAD T975
    LSIi15's front
    LSIiC center
    LSIiFX's surround
    LSIi15's rear
    PSW1000
    Sony BDPS2000ES
    2nd system
    Sony STRDA5300ES
    Sony PS3
    LSi9's front
    Klipsch sub
    under construction
  • Marty913
    Marty913 Posts: 760
    edited August 2008
    I have a couple thousand WMA Lossless files working fine on mine.
    TT = Audio Technica
