RTI 8 Bi-Amped
Hello All!! New to the forum here.
All I have to say is, boy do these RTI8's sound SOOOOOOOOOOOOO much better after bi-amping them. They really need the power and sound so much better after bi-amping them.
AVR - 100 X 7
AMP - 100 X 2
AVR - 100 X 7
AMP - 100 X 2
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
Pre - Nak CA-5
BR - LG BD390
Post edited by curved on
Congrats and Welcome to Club Polk--what/how are you bi-amping with. These speakers will surprise you. Have fun and enjoy.:)JC approves....he told me so. (F-1 nut)
Ideally I would like to get a Rotel, Parasound, etc to push it.
I just used my old AVR (both the new and the old one have almost identical specs and sound VERY similar ....100wpc @ .006 THD, etc.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
**Dayton and Sonicap Caps with Mills Resistors** -
Welcome to Club Polk Curved. Enjoy your speakers.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I was bored and tried bi-amping with two yamaha receivers (instead of using my actual amp) and honestly couldnt hear any real difference.
Even with the 200 watt amp the audio difference between that and the yamaha receiver's amp is minimal if not exactly the same at normal volume levels. -
I bi-amped my rti-8s with my onk 805 and noticed a nice increase in the bass output.
It is still bi-amped :-)Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables. -
Bi-Amping helped a TON!! I can't believe how much better they sound. And I will say that it is a lot more tunable...Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Hi,
I know this might sound silly, but I am new and learning. But I am looking and but dont quite understand. For Bi-amping do I have wires running from my reciever and amp to the connections on the speaker? or Do I have the am connect to my mains and the reciever conencted to the others? I am trying to understand correctly before I purchase more gear. Thanks for any help.
I have an Onkyo 805 and Rti8s. -
Hope this helps...Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
Hope this helps...
Thank you for the diagram. The diagram helps me a lot.:D. Do you know anything about passive bi-amp?Samsung UN46C8000
Integra DTR-70.2 9.2 channels receiver
Martin Logan Source Special Edition Front (Dark Cherry)
Polk LsiC Center speaker (Ebony) (no Cherry):frown:
Polk Lsi9 Surround (Dark Cherry)
Polk Lsi7 Back Surround (Dark Cherry)
Polk Micro PSW3000 Subwoofer
Sony Playstation 3
Thermaltake DH 103 case HTPC -
+1.
Had done this with RTi10's and Onk705 - expecting nothing. But improvement was undeniable.
Based on incredible differences of opinion re effect of Bi-Amping I've come to think that results vary significantly based on specific Speaker/Receiver combo.
Given how simple (and CHEAP) biAmping is: I feel it's always worth a try. If you're not pleased, just unhook extra cables and replace the jumpers. (DONT FORGET to Tell your Receiver for either change)LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
URGENT HELP needed - Please help me out...
My current HT config is
- Onkyo SR805 receiver
- Polk CSi A6 (Center)
- Velodyne DLS-3500R (Sub-woofer)
- 2 Polk RTi8s (front left and front right)
- 3 Bose JewelCube Speakers (3 back surround - left, center, right)
- others - PS3, A35, etc.
I bought the RTi8s yesterday at Fry's. In setting the RTi8s up , I was wondering if I need to look at bi-amping the two Front speakers. If so, should I consider the 'single-wire' option mentioned above in the thumbnails?
Please pardon my ignorance - Is there any benefit of single-wire v/s bi-amping v/s bi-wiring the front speakers? -
Personally, I would bi-wire them right away with your receiver. That way if you ever decided to bi-amp them, you already have the speaker wire there.....Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
