Onkyo TX-SR805 reciever WHat speakers?
jerryjerry1963
jerryjerry1963 Posts: 3
edited July 2008 in Speakers
I bought an Onkyo TX-SR805 receiver (specs listed below). I am in the process of buying speakers for my new house. First what is the recommendation for a receiver like this as far as a nice set of in wall speakers for the surround sound and in ceiling for auxiliary rooms on the multi zone output. I have settled on the LC265 I for the front surround, LSIC for the center ( i know it is not in wall but this is the configuration I need for the center) LC65 I for the rear surround. I can only run 5.1.
Will these speakers work well with this receiver? I read that the LSIC needs a high output at 4 ohms (dont know what this means) so started wondering about the entire system as to if it would work.
Can/should I bi amp the front speakers? will this work with using my 2nd powered zone.
I am thinking of using the LC 80 I for my kitchen from zone 2 and tc60 i for the bedroom which is less critical for me. Also for the bath, 1 RC6S
Thanks in advance for the help.
Jerry
Front L/R 130 W + 130 W (8 ohms, 20 Hz–20 kHz,
0.05%, 2 channels driven, FTC)
150 W + 150 W (8 ohms, 1 kHz, 0.7%,
160 W + 160 W (6 ohms, 1 kHz, 0.1%,
Center 130 W (8 ohms, 20 Hz–20 kHz, 0.05%,
150 W (8 ohms, 1 kHz, 0.7%, 2 channels
driven, FTC)
160 W (6 ohms, 1 kHz, 0.1%, 2 channels
driven, FTC)
Surround L/R 130 W + 130 W (8 ohms, 20 Hz–20 kHz,
Surround Back L/R 130 W + 130 W (8 ohms, 20 Hz–20 kHz,
Dynamic Power 300 W (3 ohms, 1 ch)
250 W (4 ohms, 1 ch)
150 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion) 0.05% (Rated power)
Damping Factor 60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance 200 mV/47 k-ohms (Line)
2.5 mV/47 k-ohms (Phono MM)
Output Level and Impedance 200 mV/470 ohms (Rec out)
Phono Overload 70 mV (MM, 1 kHz, 0.5%)
Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode)
Tone Control ±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio 110 dB (Line, IHF-A)
Speaker Impedance 4 ohms–16 ohms or 6 ohms–16 ohms
Post edited by jerryjerry1963 on
  • jon s
    jon s Posts: 905
    edited July 2008
    the onkyo tx-sr805 is probably one of the most powerful mainstream receivers out there... A lot better than Sony and a tad better than Yamaha and Pioneer and Denon. it should be able to handle the load but you may not be able to drive the speakers extremely loud. I don't think bi-amping is necessary but to NOT bridge the power amps with the Polks as the bridged amps cannot handle four ohm loads.
  • jerryjerry1963
    edited July 2008
    Thanks for the reply. I am not sure what you mean by bridging the amps. Could you elaborate just a bit?
  • jon s
    jon s Posts: 905
    edited July 2008
    Some Onkyos can combine two channels of amplification into one... so two 130 watt amps combines into 260 watts. The drawback is bridged amps do not work with loads under 8-ohms.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited July 2008
    Just keep it all on one channel per speaker and set the crossover and run a sub and you'll be ok. My 7 LSi speaker package is just fine with that AVR.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • mmadden28
    mmadden28 Posts: 4,283
    edited July 2008
    jon s wrote: »
    The SR805 is not bridgeable. The 875 and up are so you need not even consider it.
    ____________________
    Pool: Atrium 60's/45's
  • bopicasso
    bopicasso Posts: 878
    edited July 2008
    Maybe he meant bi-amped. Which it is capable of.
    Living Room setup: Pioneer Elite VSX-21TXH, Krell KAV 300i, PS Audio DL III DAC, Tyler Acoustics Taylo 7u, Dynaudio Audience 120C+, SVS 25/31PCI, B-P-T Clean Power Center, Ps3, Panny 50" S1 Plasma, Tekline speaker cables, Audio Art interconnects, and Pangea power cables.
  • mmadden28
    edited July 2008
    No I believe he meant bridgeable. Combining two channels for one of doubled wattage is bridging. Bi-amping would require the removal of the jumper between the binding posts. Bridging would not. The user manual is shared betwen the 805 and 875. It mentions bridging, but also states that the 805 is not capable of bridging, but of course both are for bi-amping.
    From what I understand (which is still relatively little) and read in these forums, bi-amping with the same single AVR is not true bi-amping, but probably enough to separate the highs and lows to separate cables as well as provide at least some more power to each, even if not effectively doubled--to make a difference. But then I wouldn't expect the highs to require a full 130 watts as much as the lows would chew it up.
